Go to Post To ANY Robowrangler students reading this thread: If any of you ask me about the game hint, at any time, you will be assigned 4 hours of shop cleaning duty during week 1. No exceptions. - JVN [more]
Unread 15-02-2016, 01:36
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Coding a am-2816a motor encoder.
Originally Posted by FireAmpersand View Post
First off is the wires go back to the roboRIO or straight to the Talon srx (CAN).
So the wires go to a talon Encoder Breakout board. You can find the wiring specifications on the andymark encoder description page.
In code, change the control mode of the motor
motor.changeControlMode(CANTalon.TalonControlMode.Position)
To get the sensor feedback you can view it in networktables by adding
motor.get()
and to set the motor to a certain encoder position
motor.set(int encValue)
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 15-02-2016, 01:38
FireAmpersand's Avatar
FireAmpersand FireAmpersand is offline
AKA: Manning Team Co-Captian
FRC #4627 (Manning Robotics)
Team Role: Electrical
FireAmpersand is an unknown quantity at this point
Sweet. And this follows PID control, correct?
Unread 15-02-2016, 01:41
Also is the board needed, or can we go straight to the srx's pinout?
Unread 15-02-2016, 02:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It is theoretically possible to go straight back to the SRX's pinout, but because of the fine pitch of those pins, it is preferable for most teams to use the breakout to get to a pin pitch solderable by regular humans.
Unread 15-02-2016, 02:43
Ok thats good too know, its just that its week 6 and we don't want to wait on shipping
Unread 15-02-2016, 10:16
ArchdukeTim
Yes. I forgot earlier but I think you have to set the PID before the motor will work. Generally only P is needed, but if it doesn't work too well increase I very very slightly (start at .002)
motor.setPID(P, I, D)
Unread 15-02-2016, 16:32
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
Please Help
Down below is my code and we want the robot to drive with arcade with a xbox controller also plz help me to get it to turn. And we are using the standard wheels on the robot
package org.usfirst.frc.team5713.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Talon;
public class Robot extends IterativeRobot {
RobotDrive drive = new RobotDrive(1,2,3,4);
Joystick driveStick = new Joystick(0);
Joystick controlStick = new Joystick(1);
Talon frontLeft = new Talon(1);
Talon rearLeft = new Talon(2);
Talon frontRight = new Talon(3);
Talon rearRight = new Talon(4);
public void robotInit() {
frontLeft.enableDeadbandElimination(true);
frontLeft.set(+1.0);
rearLeft.enableDeadbandElimination(true);
rearLeft.set(-1.0);
frontRight.enableDeadbandElimination(true);
frontRight.set(+1.0);
rearRight.enableDeadbandElimination(true);
rearRight.set(-1.0);
public void teleopInit(){
frontLeft.set(-1.0);
rearLeft.set(+1.0);
frontRight.set(-1.0);
rearRight.set(+1.0);
public void teleopPeriodic() {
while (isOperatorControl() && isEnabled()) {
drive.setSafetyEnabled(true);
double joystickLeftY = driveStick.getRawAxis(2);
double joystickLeftX = driveStick.getRawAxis(1);
drive.arcadeDrive(joystickLeftY, joystickLeftX, true);
Timer.delay(0.01); } }
also our team is using standard wheels and we have the middle wheel and back wheel connected to drive train and the middle wheel has two motors and the same applies to the other middle wheel. for going forward and backward can someone plz help
Unread 15-02-2016, 17:06
ArchdukeTim
Re: Please Help
Originally Posted by CyberTeam5713 View Post
RobotDrive drive;
Joystick driveStick;
Joystick controlStick;
drive.arcadeDrive(joystickLeftY, joystickLeftX, true); }
This should work.
Unread 15-02-2016, 17:13
FRC #5713
TimTheGreat
Thank You
