Go to Post Thank you GDC, for keeping everyone honest! - dtengineering [more]
Unread 14-02-2016, 22:53
JPBlacksmiths's Avatar
JPBlacksmiths JPBlacksmiths is offline
AKA: John Cashman
FRC #0806 (Brooklyn Blacksmiths)
JPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the roughJPBlacksmiths is a jewel in the rough
Dubstep motor shears
https://youtu.be/TSrwzDrnz9M
Don't you just love it when motors shear off mounts
Unread 14-02-2016, 23:40
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Dubstep motor shears
I was a bit concerned when I saw how close the PG188's stall torque was to its output shaft shear failure torque about a year ago. However, this looks like some mounting bolts sheared; is that what happened here?
Unread 15-02-2016, 00:13
AKA: John Cashman
Ye,s it was the mounting bolts that ripped out, the motor surprising escaped unscathed.
Unread 15-02-2016, 02:25
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I'm not all that surprised; the PG188 can deliver enough torque to lift a robot if you aren't particularly chuffed about speed; I considered using it for coefficient of friction tests for this reason. How many M4 bolts were in place when it sheared? Do you have logs showing how much current the PG188 was drawing when it sheared those bolts?
Unread 15-02-2016, 08:41
AKA: John Cashman
Well we were under the impression that we had M4 bolts in the motor at the time of failure, but we have come to the conclusion that we didn't have the right bolts. We have since replaced them with M4s. And I am not positive if we have those logs, we might.
Unread 15-02-2016, 08:46
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Ooo something to work with the Sally port and drawbridge. See you guys at NYC.
Unread 15-02-2016, 09:02
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
We can relate https://www.youtube.com/watch?v=BjIZBcQOSe4
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
