Go to Post You don't have to beat stronger teams to get better... to get better is to be forced to push the envelope against stronger teams. - Shankar M [more]
Unread 15-02-2016, 03:39
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
Re: Connected to Radio, Not Roborio
This may be redundant, but:
Did you statically set the IP address of your RoboRIO to 10.te.am.2?
Did you upgrade the firmware and image on the RoboRIO (two upgrades)?
Can you ping roborio-TEAM#-frc.local from your DS?
Unread 15-02-2016, 06:28
JohnFogarty's Avatar
AKA: @doctorfogarty
We'll be doing a lot of testing today, but I can say our team has experienced this issue several times this weekend.
John Fogarty
Unread 15-02-2016, 07:45
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
We set the static IP on Saturday, and it did help.
I am not sure if we upgraded firmware on roborio, I will need to check that. I know we imaged the roborio, but not sure about both steps. Thanks, will need to verify.
The sooner we get behind schedule, the more time we have to catch up.
Unread 15-02-2016, 09:36
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Could someone experiencing this problem try flushing their mDNS cache?
Instructions here:
https://documentation.cpanel.net/plu...t/view/2719759
Let us know if this helps, I saw this problem last year and it had me flummoxed. Had to turn it off and on again.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 15-02-2016, 16:02
dharg99's Avatar
dharg99 dharg99 is offline
FRC #4633
dharg99 is an unknown quantity at this point
You also need to make sure your Ethernet cable is plugged into the farthest point to the right from the power supply, the one marked 802.3af POE
#4633Lyfe
Unread 15-02-2016, 16:50
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Do you have documentation for that? Not that I don't believe you, but that's the exact opposite of what rich said...
Originally Posted by rich2202 View Post
On the radio, is the Ethernet cord for the roborio plugged into the port closest to the power plug? If not, try it there.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 15-02-2016, 19:33
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Team Update #8
https://firstfrc.blob.core.windows.n...esComplete.pdf
Unread 15-02-2016, 20:40
AKA: Matt B
FRC #1771 (1771)
Huh I must have missed that part of the update, thanks. I'll get the students to check it's in that port...
1771- Mentor (2015)
Unread 15-02-2016, 22:08
That's not what the official advice says. Team Update 8 in particular instructs teams having problems to use the "18-24v POE" port adjacent to the power connector.
