Go to Post When the world gives you lemons make lemonade serve it at your press conference to expand the program. - Koko Ed [more]
Unread 15-02-2016, 09:46
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Win a Hat! (Its a really nice hat, its a really hard problem)
Here is a picture of our labview implementation of the code for this... It calculates angle based on the distance to the tower (horizontally), the height of the opening, and the velocity of the shooter.
It's split up to make it more readable, but is essentially a quadratic formula with three terms that are each calculated from the parameters. There are 2 quad formulas because in a normal parabola, the ball will cross the opening twice (once going up, once going down), so there are two solutions. We take the closer one.
Hope this helped!
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 17-02-2016, 19:18
Plot this function with given values of Vo, d, and h vs x=0 to pi/3 radians.
Where it crosses the X axis is the angle solution in radians.
Vo = given initial (launch) speed feet/sec
d = horizontal distance from launch point to goal, feet
h = vertical height from launch point to goal, feet
Here's a detailed explanation of the derivation of the function.
