Go to Post but it was late and we were out of cardboard... - Nuttyman54 [more]
Unread 10-02-2016, 15:16
protectvariable protectvariable is offline
protectvariable is an unknown quantity at this point
NavX Error
Our team has recently been using a NavX-MXP Robotics Navigation Sensor by kauai labs. After using it for a bit we noticed that instantiating the sensor and reseting yaw, (see below picture) then using the reference in periodic tasks yielded an error like, "This SPI port is already in use", in the driverStation console. When we removed the yaw reset it worked fine. Any reasons to why this may be?
Name:	Screen Shot 2016-02-10 at 2.54.58 PM.png
Unread 10-02-2016, 23:58
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Re: NavX Error
Hmm...this is odd. I'll look at it tomorrow.
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
Unread 12-02-2016, 08:31
Re: NavX Error
I made a change to Open to register the VI refnum and our crashing issue is resolved. If anyone else using LV and navX has an every-other-time crash during development, there should be a fix up shortly, and I could tell you the edit to make if need be.
Greg McKaskle
Unread 12-02-2016, 16:19
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: NavX Error
Greg,
can you send or post the fix, we were attributing this every other crash to mDNS... we are using the navx too.
PM here is fine.
Thanks.
The sooner we get behind schedule, the more time we have to catch up.
Last edited by tr6scott : 12-02-2016 at 16:22. Reason: decided against putting my team email up in public.
Unread 12-02-2016, 16:39
Caboose's Avatar
AKA: James Parks
Re: NavX Error
I will be posting a fix for this error tonight.
myManga
Unread 12-02-2016, 17:58
Caboose's Avatar
AKA: James Parks
Re: NavX Error
Updated Library. This should fix the mentioned issue by OP and the later mentioned issue by Greg.
https://github.com/FRC900/navX-MXP-L...s/tag/v2.0.5.0
myManga
Unread 12-02-2016, 23:48
Re: NavX Error
We verified the fix. Thanks for pushing the update.
Greg McKaskle
Unread 12-02-2016, 23:57
Caboose's Avatar
AKA: James Parks
Cool Re: NavX Error
Greg McKaskle
Thank you for help with the fix.
myManga
Unread 15-02-2016, 09:46
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Re: NavX Error
Thank You!
No more every other crashes yesterday... great time saver.
