Go to Post Tolerance, forgiveness, humor, and lessons learned are tools we can find here. - JaneYoung [more]
Unread 15-02-2016, 10:36
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Pneumatic Regulators from Automation Direct
Emphasis mine:
Originally Posted by R82
“Working” air pressure on the ROBOT must be no greater than 60 psi and must be provided through a single primary adjustable, relieving, pressure regulator.
Norgren regulator P/N: R07-100-RNEA or Monnier P/N: 101-3002-1 recommended.
Looking at the spec sheet, I don't see anything about this being a relieving regulator. That is, if the low side pressure is increased to greater than 60 psi (e.g. through mechanical compression of a cylinder that pushes air back through the system), the regulator is required to relieve that excess pressure.
