Go to Post Wishes and dreams can hold a robot together just as well as nuts and bolts. - Kyle [more]
Unread 15-02-2016, 01:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: 8020 fastener question
Originally Posted by dirtbikerxz View Post
SOunds perfect. Where can i find a c channel that size? andy mark and vex dont have those sizes... do you know of another website?
We procured this locally at Bayou Steel, but it also seems to be available at OnlineMetals.com.
Unread 15-02-2016, 06:46
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
80/20 has a nice catalog. You might find a connector specifically made to do what you want. Just a note; they have American and metric sizes which can cause problem if you try to mix.
Side note: previous mentor bought metric bolts. 5 years later, I'm still finding metric bolts and tossing them out to prevent them from destroying our American sized nuts.
Dave
Unread 15-02-2016, 07:24
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is online now
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Dave
i know 8020 has those brackets, but for what we are doing, it would be over 200 dollars in brackets, or just 40 dollars in the c-channel gusset. We don't have much money.
Unread 15-02-2016, 11:42
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Stroke of good luck, turns out we do have c-channel of that size in the workshop.
Question is, do you know how long each strip of channel should be to join the two 5 foot 1x1 8020, and keep it stable. It won't have too much stress on it, we are basically using this as our pit frame. I was imagining that we use 6 inches of channel per joint. 3 inches on each strip of 8020, is that enough?
Unread 15-02-2016, 12:25
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
That sounds like a good place to start. Try building one and testing it with loads and collisions about two or three times what you expect and see how it holds up. Threading a dowel screw or hanger bolt into the end of both pieces before putting on the c-channel would also help.
