Go to Post I want to use some of that mass-less rod in our robot - saves weight. - ebarker [more]
Unread 15-02-2016, 12:33
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Can only connect to new radio after connecting over usb
Hello, I have been having some trouble with the new radio. I have an issue where the robot can only connect over wifi after we connect and disconnect over WiFi. When I turn it on with the Ethernet cable plugged into the closest connector (to the power). It connects for a seconds, then disconnects.
I have:
- Downloaded the new radio configuration utility and re-configured the radio.
- Used both ports trying the connect.
- Re-powering the radio after it tries to connect.
The old radio works fine. Has anyone else run into this issue?
Unread 15-02-2016, 12:40
Re: Can only connect to new radio after connecting over usb
We always have to ask if you are cabled to the appropriate power. This radio is different than DLink.
Unread 15-02-2016, 12:47
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
We were having those type of issues then we updated the firmware through the configure utility and haven't had any since.
jreneew2's Avatar
AKA: Drew Williams
It is hooked up to the 12V/2A connector on the VRM.
EDIT: I'll try and update the firmware.
Unread 15-02-2016, 12:53
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Have you tried hitting the reset button on the RoboRio after the Radio has powered up?
Unread 15-02-2016, 13:05
jreneew2's Avatar
AKA: Drew Williams
I hit the reset button after the radio power turned on and it worked. Is there a way to not have to reset it? That is sort of inconvenient every time we boot the robot?
Unread 15-02-2016, 15:16
Please try connecting the roboRIO and radio using the ethernet port next to the power connector.
Greg McKaskle
Unread 22-02-2016, 14:23
jreneew2's Avatar
AKA: Drew Williams
I updated to the latest DriverStation software and the problem seemed to go away. Thanks for all the help!
