Go to Post Yes, it is fun. Its fun to watch the students expand their thinking and look outside the "normal" and watch their thoughts explode! Its also fun to watch the mentor's minds fry trying to out think the students.;) - Robert Cawthon [more]
  #46   Spotlight this post!
Unread 04-02-2016, 11:02
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: mjpg-streamer running on roboRIO
Change /etc/default/mjpg-streamer. The default contents look like this:
https://github.com/robotpy/mjpg-stre...it/default#L11
  #47   Spotlight this post!
Unread 04-02-2016, 11:34
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
What text editor does the RoboRio have installed? Or can I use something like FileZilla?
  #48   Spotlight this post!
Unread 04-02-2016, 12:04
virtuald's Avatar
RobotPy Guy
vi.
You could use filezilla. Better in the long term to learn how to use vi.
  #49   Spotlight this post!
Unread 07-02-2016, 22:23
I got viewing the stream from mjpg-streamer working on the LabVIEW dashboard also. Use "BB_CameraDirectly from MJPG-Streamer.vi" from the attached zip.
  #50   Spotlight this post!
Unread 08-02-2016, 15:04
team-4480's Avatar
Debug? What's that?
FRC #4480
Does anyone know how save the exposure settings? We are using the control panel in the web interface in mjpg-streamer. The settings work but they don't save over a reboot. Any ideas?
Thanks!
  #51   Spotlight this post!
Unread 13-02-2016, 11:10
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Thanks!
We would also like to be able to set the exposure manually through this as well. I was looking through the code and I only saw a setControl function and could not figure out where that came from. I am not very good at javascript or html so I would appreciate some guidance.
I was thinking that if we could find where those values are defined, we could manually set them. But I think they are in the hardware of the camera, so I'm not sure if we could set them. Or you could make a script to automatically set the values at start. I'm not sure how to do that either...
  #52   Spotlight this post!
Unread 13-02-2016, 12:22
virtuald's Avatar
RobotPy Guy
Thanks!
I will bring a camera home tonight and make it work.
  #53   Spotlight this post!
Unread 14-02-2016, 16:43
virtuald's Avatar
RobotPy Guy
I've uploaded mjpg-streamer release 2016.2.0 to the ipkg repo, which will allow you to pass the following settings to the input plugin (via the INPUT[1] line of /etc/default/mjpg-streamer):
 Optional parameters (may not be supported by all cameras):
 [-br ].................: Set image brightness (auto or integer)
 [-co ].................: Set image contrast (integer)
 [-sh ].................: Set image sharpness (integer)
 [-sa ].................: Set image saturation (integer)
 [-cb ].................: Set color balance (auto or integer)
 [-wb ].................: Set white balance (auto or integer)
 [-ex ].................: Set exposure (auto, shutter-priority, aperature-priority, or integer)
 [-bk ].................: Set backlight compensation (integer)
 [-rot ]................: Set image rotation (0-359)
 [-hf ].................: Set horizontal flip (true/false)
 [-vf ].................: Set vertical flip (true/false)
 [-pl ].................: Set power line filter (disabled, 50hz, 60hz, auto)
 [-gain ]...............: Set gain (auto or integer)
 [-cagc ]...............: Set chroma gain control (auto or integer)
Additional notes can be found here.
  #54   Spotlight this post!
Unread 14-02-2016, 17:57
jreneew2's Avatar
AKA: Drew Williams
Thanks! I will test this tomorrow!
  #55   Spotlight this post!
Unread 14-02-2016, 21:44
vScourge's Avatar
vScourge vScourge is offline
Videogame Developer
AKA: Adam Pletcher
FRC #4096 (Ctrl-Z)
vScourge will become famous soon enough
Thanks for this. Is this build specifically for running on the RoboRio? We use mjpg-streamer on the Raspberry Pi, but we'd like to use a build that has these image control options.
  #56   Spotlight this post!
Unread 14-02-2016, 22:06
virtuald's Avatar
RobotPy Guy
The source code is at https://github.com/robotpy/mjpg-streamer if you wish to compile a version for a different platform. I also made a pull request to the most active mjpg-streamer fork.
  #57   Spotlight this post!
Unread 14-02-2016, 23:30
NegaNexus NegaNexus is offline
AKA: Thys Ballard
FRC #2130 (Alpha+)
NegaNexus is an unknown quantity at this point
I'm having connectivity issues when the mjpg-streamer daemon service starts at boot. I placed the files in /home/lvuser/mjpg-streamer-182. I tried to set it up so that the server would startup at boot by adding
#!/bin/sh
cd /home/lvuser/mjpg-streamer-182/
sh start.sh
to a new CAM.sh script in /etc/init.d and then typing into the shell:
$ update-rc.d /etc/init.d/start.sh defaults
The interesting part is when I attempt to reboot and connect to the robot. It never connects until I unplug the camera, which kills the mjpg-streamer daemon. I can then manually start mjpg-streamer over SSH without issue, but no dice with an at boot start. Does anyone have any ideas?
  #58   Spotlight this post!
Unread 14-02-2016, 23:54
virtuald's Avatar
RobotPy Guy
Sounds like you're going about it the hard way. Install the mjpg-streamer package from https://github.com/robotpy/roborio-packages and it'll automatically boot at startup.
  #59   Spotlight this post!
Unread 15-02-2016, 10:38
jreneew2's Avatar
AKA: Drew Williams
How would you connect opencv code running on the roboRIO to the jpeg stream. (in c++). I've seen your code in python, but where are you getting that IP from? I've tried numerous ips and can't seem to connect it. I can connect the the page fine and see the stream at http://roboRIO-2053-frc.local:5800/?action=stream, but I don't know what IP to enter in the code. do you have to set a static ip for the camera?
EDIT: I've also tried doing this (after looking on google for a bit):
videoCapture.open("http://roborio-2053-frc.local:5800/?action=stream?dummy=param.mjpg");
Nothing. Any suggestions?
  #60   Spotlight this post!
Unread 15-02-2016, 13:17
jreneew2's Avatar
AKA: Drew Williams
Also, I know the code works, because it connected to an axis camera fine. I'm pretty sure it cannot recognize the stream or it is not "looking" for it in the right place.
