Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 15-02-2016, 13:25
couvillion couvillion is offline
FRC #1818
couvillion is an unknown quantity at this point
SD read/write numbers
Where is the SD read functions? I can't find them in the menu structure.
Where did my life go wrong?
Unread 15-02-2016, 13:58
Re: SD read/write numbers
SD and NT VIs were merged. If you wire a variable starting with /, it is an absolute path. If it doesn't, /SmartDashboard/ is prepended. So the palettes only contain the NT version, but the SD VIs will continue to work if you have them in some legacy code.
Greg McKaskle
