Go to Post And the only person who could really save my butt, Brandon Martus... is sitting across the table from me. Laughing. - Amanda Morrison [more]
Unread 15-02-2016, 14:04
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: mjpg-streamer running on roboRIO
Originally Posted by virtuald View Post
To connect to an mjpg stream with OpenCV's VideoCapture object, OpenCV needs to have libav/ffmpeg support compiled in. The version of OpenCV that I distribute does not currently have libav support (see issue #2). That's interesting that you were able to connect to an Axis camera, as that would also require libav.
When running the code on the RoboRIO, you should be able to use this URL: http://localhost:5800/?action=stream
EDIT: It's possible that OpenCV 3.x does not require libav to connect to an mjpg stream.. but I know OpenCV 2 did require it. If you're connecting to the stream separately then that's would work too.
Alright, thanks. I'm not sure what you mean when you said "If you're connecting to the stream separately then that would work too". Are you saying that over a web browser?
EDIT: So, is there an issue with linking libav to opencv? Also, I had an axis camera working on opencv 2.4.10, not 3.0. Maybe this will help you?
So, running the vision code with mjpg streamer on the roboRIO is out of the question at the moment? If so, would the next logical step to have vision run on the driver station computer? If so, how would I go about doing that?
Thanks again,
Drew
