Go to Post Ha, our 2009 robot's nickname was Sparky, for the same reason...we now have EXTRA fire extinguishers because of it ;P - Karibou [more]
Unread 15-02-2016, 15:28
klhutchi klhutchi is offline
FRC #5736
klhutchi is an unknown quantity at this point
Re: PCM output LED not lighting
We are in java code. Will post below, We hardwired the solenoid to at 24V battery series and got it to light up, also manual fired the Solenoids with the blue screws at the top.
Unread 15-02-2016, 15:49
FRC #5736
package org.usfirst.frc.team5736.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.DoubleSolenoid;
public class Robot extends SampleRobot {
Joystick stick;
DoubleSolenoid gearShift;
public void robotInit() {
stick = new Joystick(0);
gearShift = new DoubleSolenoid(0, 1);
public void teleopInit() {
gearShift.set(DoubleSolenoid.Value.kForward);
public void teleopPeriodic() {
if (stick.getRawButton(2)) {
else if (stick.getRawButton(3)) {
gearShift.set(DoubleSolenoid.Value.kReverse);
Timer.delay(.005);
Unread 17-02-2016, 10:37
FRC #5736
We fixed it. The issue was that we were using SampleRobot rather than IterativeRobot. The teleoperated commands are not contained within SampleRobot.
