Go to Post They improvised. They overcame. They persevered. And they succeeded. ... I cannot remember being more proud of a group of students with which I have been associated. - dlavery [more]
Unread 15-02-2016, 14:10
klhutchi klhutchi is offline
FRC #5736
klhutchi is an unknown quantity at this point
PCM output LED not lighting
We are trying to use Pneumatics for the first time and believe we have the PCM wired correctly. When enabled we have the strobe flashing green light on status but none of the output Solenoid LED's under the ports will light up. Any ideas as to the issue, Coding? Wiring? or possibly a dead PCM...
we have 24V Festa Double solenoids and switched the PCM to 24V bridge, but cannot send voltage to the outputs anyone have similar issues.
Thanks for your help/insight
Unread 15-02-2016, 15:10
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
Re: PCM output LED not lighting
It is probably coding. What language are you using? LabVIEW has examples that you can run that will allow you to turn on and off 1 solenoid each time it is run.
What other steps have you tried?
Unread 15-02-2016, 15:28
FRC #5736
We are in java code. Will post below, We hardwired the solenoid to at 24V battery series and got it to light up, also manual fired the Solenoids with the blue screws at the top.
Unread 15-02-2016, 15:49
FRC #5736
package org.usfirst.frc.team5736.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.DoubleSolenoid;
public class Robot extends SampleRobot {
Joystick stick;
DoubleSolenoid gearShift;
public void robotInit() {
stick = new Joystick(0);
gearShift = new DoubleSolenoid(0, 1);
public void teleopInit() {
gearShift.set(DoubleSolenoid.Value.kForward);
public void teleopPeriodic() {
if (stick.getRawButton(2)) {
else if (stick.getRawButton(3)) {
gearShift.set(DoubleSolenoid.Value.kReverse);
Timer.delay(.005);
Unread 17-02-2016, 10:37
FRC #5736
We fixed it. The issue was that we were using SampleRobot rather than IterativeRobot. The teleoperated commands are not contained within SampleRobot.
