Go to Post I think that this clearly indicates that 2017 will be the year we finally see 3.63 robots per alliance. - Caleb Sykes [more]
Unread 15-02-2016, 15:03
robinspi's Avatar
robinspi robinspi is offline
Design Captain
AKA: Philip
FRC #5450 (SHREC)
Team Role: CAD
Rookie Year: 2015
robinspi is an unknown quantity at this point
Router on top of RoboRio
So, my team wants to try something a little different, and this involves something maybe somewhat unusual.
Would it be legal to stack the Router (the small one which was given out this year) on top of the RoboRio? The router fits perfectly on top of the RR, and it doesn't obstruct any ports or anything. It is just sitting on top of it, taped and zip-tied down (not to tightly with the zip-ties though... don't want to damage the RR ).
Just asking to make sure we don't have to change it right before inspection and maybe break something. Never hurts to double-check, right?
Design/CAD Manager for FRC Team 5450 :: SHREC
Unread 15-02-2016, 15:07
Re: Router on top of RoboRio
I can't find anything to prohibit this setup.
However, the inspector may want to get at the RoboRIO to verify other rules regarding what must be connected to it.
Unread 15-02-2016, 15:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have done this as well. As long as all ports and lights are visible (including the MXP, even if you're not using it), I didn't find anything against it. Remember that you will have to remove the radio at the event for configuration for use with the FMS.
