Go to Post I want to see the [game] animation robot with the plunger to pick up balls and the boots that spin to kick them. Could you do that please. It would be very awesome. :D - the man [more]
Unread 15-02-2016, 15:17
Team 3023 Team 3023 is offline
FRC #3023
Team 3023 is an unknown quantity at this point
Help with Errors
Hey, we are new to programming and when we run the code, we get this error.
ERROR Unhandled exception: java.lang.RuntimeException:
 Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.allocatePWMChannel(Native Method),
 edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:117),
 edu.wpi.first.wpilibj.PWM.<init>(PWM.java:134),
 edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java:35),
 edu.wpi.first.wpilibj.Talon.<init>(Talon.java:51),
 org.usfirst.frc.team3023.robot.DriveTrain.<init>(DriveTrain.java:10),
 org.usfirst.frc.team3023.robot.Robot.robotInit(Robot.java:122),
 edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:72),
 edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)]
We are wondering if anyone has a solution to this
Unread 15-02-2016, 15:26
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
Re: Help with Errors
You are trying to allocate the same PWM more than once.
Unread 15-02-2016, 15:43
TimTheGreat's Avatar
TimTheGreat TimTheGreat is online now
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
For clarification, somewhere in your code you have
motor = Talon(0) //or a different number
then later in your code you have
motor = Talon(0)//or a different number, but same number as before
You can't assign two motor to the same PWM in code. If it so happens that you want to run two motors the exact same way (for a gearbox perhaps?) then you should use a pwm splitter (KOP I believe)
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 15-02-2016, 22:57
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
I'm guessing you already fixed this problem with previous comments. An alternate to the PWM splitting in hardware is to map it in software. This can make life easier for your mechanical/electrical teams because they just plug each motor into a PWM slot and then you write the same value out multiple times in each software iteration:
init:
motor1 = Talon(0);
motor2 = Talon(1);
loop:
desiredMotor = 250;
motor1.Set(desiredMotor);
motor2.Set(desiredMotor);
2008-2011: #226 - The Hammerheads
