Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 15-02-2016, 17:01
codetheweb's Avatar
codetheweb codetheweb is offline
FRC #3299 (The Warehouse Crew)
codetheweb is an unknown quantity at this point
I2C with Arduino
I'm having some trouble communicating with the Arduino over I2C.
We're planning to use it for LED strips, since almost all our PWM slots are taken. But most examples I find online use Java, not Python. Is there any way to easily write a string over I2C? For example, writing something like "rgb,10,0,255" would turn on the RGB strip.
Unread 15-02-2016, 17:06
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: I2C with Arduino
Can you post a link to java code that you think will solve your problem?
Unread 15-02-2016, 17:10
codetheweb's Avatar
Here.
Originally Posted by Rakusan2 View Post
My team got the Arduino communicating with the roborio over I2C using the following code on the roborio
static I2C Wire = new I2C(Port.kOnboard, 4);
if (Global.driver.Buttons.Back.changedDown) {
	String WriteString = "go";
	char[] CharArray = WriteString.toCharArray();
	byte[] WriteData = new byte[CharArray.length];
	for (int i = 0; i < CharArray.length; i++) {
		WriteData[i] = (byte) CharArray[i];
	Wire.transaction(WriteData, WriteData.length, null, 0);
And this code on the Arduino
#include <Wire.h>
void setup()
  pinMode (13, OUTPUT);
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
void loop()
  delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
  String LED = "";
  while ( Wire.available() > 0 )
    char n=(char)Wire.read();
    if(((int)n)>((int)(' ')))
   LED += n;
  if (LED == "go")
    digitalWrite (13, HIGH);
Unread 15-02-2016, 17:23
virtuald's Avatar
RobotPy Guy
First part, should be pretty straightforward.
wire = wpilib.I2C(wpilib.I2C.Port.kOnBoard, 4)
Second part -- I admit the docs aren't super clear here, but it wants you to pass it a list of things that can be converted to bytes... so either integers or a bytestring.
wire.transaction(b'go', 0)
I'm pretty sure that'll work.
It's weird that the java code isn't trying to receive any data (maybe writeBulk is more appropriate?).
Unread 18-02-2016, 18:28
codetheweb's Avatar
Thanks, works great! In case anyone else stumbles across this, here's the code I used:
import wpilib
class MyRobot(wpilib.IterativeRobot):
    def robotInit(self):
        self.stick = wpilib.Joystick(0)
        self.arduino = wpilib.I2C(wpilib.I2C.Port.kOnboard, 4)
    def teleopPeriodic(self):
        if (self.stick.getTrigger()):
            try:
                data = self.arduino.transaction(b'go', 0)
            except:
                pass
        else:
            try:
                data = self.arduino.transaction(b'stop', 0)
            except:
                pass
if __name__ == "__main__":
    wpilib.run(MyRobot)
And
#include <Wire.h>
void setup()
  Serial.begin(9600);
  Serial.print("Hello");
void loop()
  delay(100);
  String rxString = "";
    rxString += n;
  Serial.print(rxString);
Unread 18-02-2016, 20:38
virtuald's Avatar
RobotPy Guy
Awesome, I like how much shorter it is than the Java version:
