Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 15-02-2016, 12:22
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Losing connection when ramping over defenses
Has anyone else experienced this? I have checked and made sure that all of the wiring is good on our robot, yet every time we ramp over a defense (i.e. rock wall) and slam down, our robot drops connection. All wires are secured and locked in to their ports (power, ethernet, pwm, etc.)
Could this be a result of shock causing the radio/roboRIO to reboot?
If you have had this problem, please share your solutions.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 15-02-2016, 12:42
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Losing connection when ramping over defenses
Check your main breaker to make sure it isn't bad. There are a couple each year... With the bad ones, you can tell by lightly tapping on the red button while watching the LED's on the robot - with a bad one they'll flicker.
My team's main breaker was bad, but in a different way- the lever inside that lets you turn it on was broken. Brand new, out of the box for may be a day. It was the only one I've seen broken like that. Fortunately, we had a few spares sitting around
2016: Lake Superior WFFA
Unread 15-02-2016, 12:43
Double check that the fuses on the PDP are full inserted. They can look good but are actually far from fully mating. Are you getting just a very short (one or two seconds) drop or are you getting a radio reboot?
Unread 15-02-2016, 12:46
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We had this happen to us a few times Saturday during our first test drives over the defenses. We are going to do trouble-shooting this evening. I also saw another thread that described a similar (possibly the same) problem.
Unread 15-02-2016, 12:47
Landonh12's Avatar
270 points
AKA: Landon Haugh
It seems like a radio reboot, I'm just speaking from what the students have told me. It goes down for a good 30 secs.
I'll check the main breaker as well. Thanks guys.
Unread 15-02-2016, 12:49
What do you learn from the driver station logs? http://wpilib.screenstepslive.com/s/...og-file-viewer
Unread 15-02-2016, 12:53
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
We have been experiencing this exact same issue. When we go over the defences we drop connection. We have isolated the issue to the roborio. We're still trying to figure out how to fix it. We're currently trying to add suspension to our roborio and hoping that fixes it.
Unread 15-02-2016, 12:55
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
What power plug in to the radio are you using? Wiggle it. If you do not get stable power, that might be your problem.
Landonh12's Avatar
270 points
AKA: Landon Haugh
I haven't personally seen any of the logs, but I can check when I get to the meeting this afternoon. Usually there aren't any errors from what I've seen, but I could be wrong.
Unread 15-02-2016, 12:56
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
We had this happen last night too. The power connector for the radio came unplugged while going over the rock wall.
Unread 15-02-2016, 13:35
Procolsaurus's Avatar
Procolsaurus Procolsaurus is offline
AKA: Robert Pond
FRC #4118 (Roaring Riptide)
Procolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really nice
We had very similar comms issues, which were solved by checking the fuses.
2011-2012 Team 180 student
2014-Now Team 4118 College Mentor
2014 Referee, 3 events
2015 Field Reset, Referee, Scorekeeper
Unread 15-02-2016, 16:23
Those minifuses are very good at pretending to be fully seated when they really aren't. My advice to teams for getting them in all the way:
  • Push them in all the way.
  • Let go and notice how they look like they're in all the way.
  • Push harder. Literally until it hurts.
  • Notice that they go in a lot more.
As a rule of thumb (!), if you can pull them out with your fingers they aren't pushed in hard enough.
Unread 15-02-2016, 16:55
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
If your using a two speed transmission check to make sure your in low.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 15-02-2016, 17:15
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Would you be able to post a video of how hard you guys breach?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 15-02-2016, 18:05
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
This leads to an interesting question: with all of the rough defenses, will bots have increasing comm problems during the tournaments as the systems get shaken up?
