Go to Post if you want to repay us for the omni-wheels, use the money to help out a few rookie teams next year. Buy them batteries or help build them bumpers, anything you see fit will be much better than cash back to us. - AllenGregoryIV [more]
Unread 15-02-2016, 13:31
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
navX MXP - anyone have an extra?
AndyMark and Kauai Labs are both currently out of stock of the navX MXP Robotics Navigation Sensor (am-3060a) and we are looking to acquire one fairly quickly (week 2 is our first event). If a team has a new one sitting around that they are not planning to use this year, we would love to have a chance to buy it off of them.
Anyone?
Thanks!
Nate
Unread 15-02-2016, 18:07
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: navX MXP - anyone have an extra?
Anyone?
Thanks!
If no navX-MXP is available, another option you might consider is to use a navX-Micro. You can communicate with this device using the same LabVIEW/C++/Java/Python/C# libraries as the navX-MXP. The navX-Micro is the smaller version of the navX-MXP. The navX-Micro has USB and I2C interfaces, so because of the USB issues which have been discovered w/the 2016 RoboRIO firmware, you could use the I2C interface.
Unlike the navX-MXP, the navX-Micro doesn't have the MXP Expansion IO feature, and it doesn't mount directly on top of the RoboRIO - but a 3d-printable enclosure is available. The navX-Micro also doesn't have the SPI and TTL UART interfaces provided by the navX-MXP - but the I2C interface should work fine for your needs.
If that sounds like an option for you, they can be purchased at the KauaiLabs online store.
Unread 15-02-2016, 18:10
Software Mentor
AKA: Scott Libert
P.S. A shipment of navX-MXPs is on its way to AndyMark, they should be available for sale there on about 4/26/2016.
