Go to Post Being inspired is a lot like learning, not everybody does it the same way. - Jay Trzaskos [more]
Unread 15-02-2016, 19:56
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Re: Losing connection when ramping over defenses
Originally Posted by Citrus Dad View Post
This leads to an interesting question: with all of the rough defenses, will bots have increasing comm problems during the tournaments as the systems get shaken up?
I would not be surprised. This game will *probably* put more stress on robots than Aerial Assault due to the fact that you're pretty much required to go over the defenses.
BTW, we haven't been able to run the robot tonight. Still wiring up sensors and putting some final touches on before we get the code debugged and start practicing.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 15-02-2016, 20:02
scrblnrd3 scrblnrd3 is offline
FRC #4795
scrblnrd3 is an unknown quantity at this point
We had this problem as well, and we noticed that it was because the ethernet port in the RoboRio was coming loose. We fixed it by using the socket saver from the KOP and ziptieing it to the RoboRio so it had a firm connection even when it was being pulled on.
