Go to Post I've never encountered a motor as forgiving as a CIM - Stall them for 20 seconds, run them hot on a short turnaround, or call them mean names in between matches and they'll just keep doing their thing. - thefro526 [more]
Unread 02-15-2016, 04:27 PM
UnTrustedTruss UnTrustedTruss is offline
Local Nutter
Rookie Year: 1492
UnTrustedTruss will become famous soon enough
Nav X error
My programming team has been running into an issue with the nax mxp libraries. We have been trying to use the robot example that comes with the c++ download for the imu. However after much difficulty with the libraries it is now throwing a single error on the imu inizilation. On imu = new IMUAdvanced(serial_port, 50); it says "invalid new-experssion of abstract class type 'IMUAdvanced.' " Do you guys have any ideas of what we might have done wrong or could otherwise fix this issue?
Unread 02-15-2016, 09:15 PM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Nav X error
With the NavX, I believe you should be using the AHRS class. See the NavX docs: http://www.pdocs.kauailabs.com/navx-...o-libraries/c/
