Go to Post If you never reach out and experiment with different things, you will never have the courage to reach out again. It's only through experiments and experiences where we get to understand ourselves better. - Ken Leung [more]
Unread 15-02-2016, 19:56
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Re: Losing connection when ramping over defenses
Originally Posted by Citrus Dad View Post
This leads to an interesting question: with all of the rough defenses, will bots have increasing comm problems during the tournaments as the systems get shaken up?
I would not be surprised. This game will *probably* put more stress on robots than Aerial Assault due to the fact that you're pretty much required to go over the defenses.
BTW, we haven't been able to run the robot tonight. Still wiring up sensors and putting some final touches on before we get the code debugged and start practicing.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 15-02-2016, 20:02
scrblnrd3 scrblnrd3 is offline
FRC #4795
scrblnrd3 is an unknown quantity at this point
We had this problem as well, and we noticed that it was because the ethernet port in the RoboRio was coming loose. We fixed it by using the socket saver from the KOP and ziptieing it to the RoboRio so it had a firm connection even when it was being pulled on.
Unread 15-02-2016, 20:07
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Originally Posted by roystur44 View Post
If your using a two speed transmission check to make sure your in low.
Can someone explain why this would be a problem? Currently, we are able to go over the B+D defenses by starting low and shifting to high to gain momentum which gets us over the defenses. If this is actually a problem, we might have some serious problems.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 15-02-2016, 21:15
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
If you are going over the defenses in a high speed gear, you may not have enough torque to the wheels / belts to actually climb. You can stall the motors, potentially causing the thermal breakers to break, and possibly causing the system voltage to drop below the reset point.
Use the recording capabilities and look at total current draw and voltage drop as you drive over defenses and around the field.
You can also use JVNs drive design tools to look at your drive design and the estimated loads.
My response is all based on a hypothetical situation, not one we actually experienced this season ...
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 15-02-2016, 21:39
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
We had a similar problem with the radio dropping out. I believe all we did to fix it was secure all the connections and tape the power plug to the radio.
Head Programmer / Driver
Unread 15-02-2016, 22:08
flipthedog's Avatar
flipthedog flipthedog is offline
Member of Team 1389
AKA: Floris
FRC #1389 (The Body Electric)
flipthedog is an unknown quantity at this point
So we were practicing all day on Saturday while repeatedly having connection issues when driving over defenses or if we suddenly accelerated. We thought it was our router and so we taped it up completely. However it was indeed the fuses.
Unread 15-02-2016, 23:04
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Sounds like the FTAs (and CSAs to a lesser degree) will be busy this year. At least the bandwidth induced xmas-trees should be a thing of the past. Good trade?
Unread 15-02-2016, 23:08
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Also the fact that no teams have spare radios is kind of an issue. Our team is marking our spare radio the one part we will not lend.
Unread 15-02-2016, 23:17
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by Jon Stratis View Post
My team's main breaker was bad, but in a different way- the lever inside that lets you turn it on was broken. Brand new, out of the box for may be a day. It was the only one I've seen broken like that. Fortunately, we had a few spares sitting around
We had the same issue a couple years ago, had to mash the lever or a little bit of vibration would cut power to the bot. OP, if it isn't your breaker, check to see if the power cable for your router is firmly attached. We found that those hard impacts can cause it to get loose unless securely mounted. If it's available to you, I strongly suggest a 3D printed holder for the plug to keep it well secured.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-02-2016, 23:25
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
We have been having this issue, and I think ours came from the voltage supply blacking out. We plan to modify our drive train so that hopefully it won't recur.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 15-02-2016, 23:30
Valkonn's Avatar
Valkonn Valkonn is offline
AKA: Paulo Garcia
FRC #3495 (Mindcraft Robotics)
Valkonn is an unknown quantity at this point
We had the exact same problem, it was a faulty connection between the on/off switch and the PDP. It was loose on the PDP end causing voltage to drop for a moment and the robot to reset.
Unread 15-02-2016, 23:31
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
C.Lesco will become famous soon enough
We are having the same problem, one of our mentors pointed out that our battery connection termintals was loose, maybe check that?
Unread 15-02-2016, 23:39
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
One issue that could be occurring, is a problem with dropped packets.
Last year we picked up on this issue when testing driving over the step quickly. I guess the extra stress was making us notice.
One thing that can cause alot of dropped packets is programs on the computer trying to connect to the internet.
I think in our case it was the NI or Autodesk auto updater.
I believe the problem is those eat up bandwidth trying to look for updates, and with them not being connected to internet they obviously won't be able to update and just eat bandwidth.
I'm not sure if we were throttling our bandwidth to competition levels or not when this happened.
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 15-02-2016, 23:44
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
We had this issue. Tightening the bolts that held the battery/breaker leads to the PDP solved the problem for us.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 16-02-2016, 01:41
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Our radio kept rebooting when going over the rock wall. Turned out to be a loose wire from the PDP to the VRM.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
