Go to Post To quote Dylan, "When you aint got nothing, you got nothing to lose". - KenWittlief [more]
Unread 02-15-2016, 07:09 PM
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
Help ME PLEASE ASAP
Can someone please fix my code or point me in the right direction so i can use a xbox controller to drive. tank drive or arcade drive it doesnt matter
public class Robot extends IterativeRobot {
RobotDrive drive = new RobotDrive(1,2,3,4);
Joystick mXboxController = new Joystick(0);
Joystick controlStick = new Joystick(1);
Talon frontLeft = new Talon(4);
Talon rearLeft = new Talon(3);
Talon frontRight = new Talon(2);
Talon rearRight = new Talon(1);
public void robotInit() {
drive = new RobotDrive(0,1,2,3);
frontLeft = new Talon(1);
frontLeft.enableDeadbandElimination(true);
frontLeft.set(+1.0);
rearLeft = new Talon(2);
rearLeft.enableDeadbandElimination(true);
rearLeft.set(-1.0);
frontRight = new Talon(3);
frontRight.enableDeadbandElimination(true);
frontRight.set(+1.0);
rearRight = new Talon(4);
rearRight.enableDeadbandElimination(true);
rearRight.set(-1.0);
public void autonomousInit() {
frontLeft.set(-1.0);
rearLeft.set(+1.0);
frontRight.set(-1.0);
rearRight.set(+1.0);
public void autonomousPeriodic() {
while (isAutonomous() && isEnabled()) {
drive.setSafetyEnabled(true);
drive.drive(-0.5,0.0);
Timer.delay(5);
drive.drive(0.0,0.0);
public void teleopInit(){
rearLeft.set(+1.0);
public void teleopPeriodic() {
while (isOperatorControl() && isEnabled()) {
double speedControl = 1;
double joystickLeftY = mXboxController.getRawAxis(1)*speedControl;
double joystickLeftX = mXboxController.getRawAxis(0)*-1*speedControl;
drive.arcadeDrive(joystickLeftY, joystickLeftX);
Unread 02-15-2016, 07:21 PM
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
Re: Help ME PLEASE ASAP
Add one of these to the end }
Unread 02-15-2016, 07:23 PM
FRC #5713
and the code will work?
Unread 02-15-2016, 08:03 PM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
You are declaring and initializing a RobotDrive and you are also declaring your drivetrain Talons individually.
You need to do one or the other, but not both. Doing this will throw an error saying you are declaring and initializing all your drivetrain Talons twice.
Pick which way you want to program your robot: either using the simpler RobotDrive object, or by manually coding commands to your individual Talons, then delete all the code for the method you are not using.
In the future, it is also a good idea to post a description of the problem you are encountering, including any exceptions or errors messages.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 02-15-2016, 08:43 PM
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Originally Posted by Mr. Lim View Post
[code]
Not necessarily. You can do
Talon = new Talon(0)
Talon2 = new Talon(1)
Talon3 = new Talon(2)
Talon4 = new Talon(3)
drive = new Robotdrive(Talon, Talon2, Talon3, Talon4)
You can do this way, but if you assign the ports to robotdrive then no, you can't do both.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 02-15-2016, 09:49 PM
FRC #5713
Thanks Guys
