Go to Post Push the envelope a little, but not too much. There's a difference between being on the cutting edge and being on the bleeding edge. - cadandcookies [more]
Unread 15-02-2016, 23:40
Spinoff Spinoff is offline
Spinoff will become famous soon enough
Re: 15% Off - The Pulsinator
Originally Posted by Joe Ross View Post
Have you tested the Pulsinator with the Talon SRX, Spark, or SD540B?
Yes, great question! The Pulsinator has been tested and is fully compatible with the Talon SRX, Spark, and the SD540B motor controllers. The Pulsinator outputs a standard PWM drive signal with a high time ranging from 1.0 - 2.0ms. This makes the Pulsinator compatible with every motor controller that uses that standard configuration.
Unread 15-02-2016, 23:47
What about signal strength? How many mA can the Pulsinator deliver into a 150 ohm load?
Is the signal strong enough to command 2 Victor 888 controllers with a Y cable?
Unread 16-02-2016, 23:34
Good question! The Pulsinator has a maximum output current of 40mA. (For reference the RoboRio's PWM channels are current limited to 15mA.) This makes the Pulsinator great for driving multiple motor controllers with a splitter cable. The Pulsinator has been tested driving 3 motor controllers (Talon SR, Talon SRX, Victor 888, Jaguar, Spark) using a three way splitter, and it works very well, giving full speed in both directions. This makes the Pulsinator a great tool for testing drivetrain gearboxes or other applications.
