Go to Post It's all about bragging rights, awards, and pushing the envelope, not necessarily winning or practicality. - ahecht [more]
Unread 16-02-2016, 05:23
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Re: Jetson TK1 from First Choice Keeps Failing
Try running 'fsck' on the root filesystem as root.
# fsck -f /dev/root
When the error occurs, the fs will already be mounted read only.
The -f flag should force a check even though its an ext4 fs.
Unread 16-02-2016, 13:13
We had pretty bad luck with the reliability of the TK1. At one point, we had 2 that flat out refused to boot. I'd be careful if you decide to run this on your robot
Unread 16-02-2016, 13:19
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Ouch...
We have not had those issues. Would highly recommend putting them in a case of some sort though. We also ran ours off of the VRM last year if that helps.
The TX1 is proving to be more of a challenge however... It seems very prone to power fluctuations.
