Go to Post I can't wait till FIRST starts giving anti-gravity kits inside the kit of parts. - Rob Colatutto [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 16-02-2016, 08:27
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is on a distinguished road
Issue with Stateful Autonomous/Smart Dashboard
So, I've got the stateful autonomous setup and running (love how easy it was, by the way). When I sim the robot in pyfrc, the options all show up in the drop down.
However, when I throw the code on the bot, I have no idea where to look to find the chooser? We're on the vanilla drivers station, direct from the 2016 image.
Any suggestions for a rookie team who is *really* feeling the end of build season?
Unread 16-02-2016, 09:01
WubbaDuck WubbaDuck is offline
FRC #0074 (Chaos)
WubbaDuck is an unknown quantity at this point
Re: Issue with Stateful Autonomous/Smart Dashboard
Which dashboard are you using? There are several options, but the Java Smartdashboard is the one we are using. It just shows up on the dashboard after you initialize it in the code. To install it you will need Eclipse and the wpilib addons that go with that. Here is a good resource for getting this all set up https://wpilib.screenstepslive.com/s/4485/m/26401
FRC #5929
As I read a bit more, I notice some other code examples showing that you need some code on the drivers station...
Where would I put that? Our experience with the drivers station so far is turning it on when we want to drive, making sure we're enabled, teleop, etc, and using it to make sure our USB mappings are correct...
Unread 16-02-2016, 09:02
FRC #5929
I'm using the Dashboard that came pre-installed on the Classmate. The title bar states "FRC PC Dashboard".
Is that a different dashboard?
Unread 16-02-2016, 09:07
FRC #0074 (Chaos)
Yeah, it is different. The built in one is LabView based, I believe and the Java SmartDashboard allows for a ton of customization like adding an auton chooser.
Unread 16-02-2016, 09:08
FRC #5929
Well, that'll be the first thing to check then. Thanks so much!
Unread 16-02-2016, 09:58
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
The LabVIEW version allows for the same customization. You can do what ever you want to do.
Unread 16-02-2016, 10:43
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
You shouldn't need to put any code on DS. If you use eclipse then get the wpilib plugin (instructions found here)
Run smartdashboard from the wpilib menu bar and connect to roborio-XXXX-frc.local (XXXX is team #). In the Autonomous Mode folder you need to add the key "selected" and make the value the MODE_NAME of the mode you want to run.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 16-02-2016, 11:05
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
The short answer is that which was said above: get SmartDashboard running (which I think you can select in the DS if you set it to "Java Dashboard") and the autonomous chooser will just show up. However, customizing SmartDashboard and (in particular) making it pretty is fairly annoying.
With that in mind, I'll give you another option: pynetworktables2js
It makes building a dashboard and interacting with the robot as easy as making a webpage! The example program has an 'autonomous.html' page that shows a combo box which lets you choose autonomous modes.
https://github.com/robotpy/pynetwork...master/example
Unread 16-02-2016, 11:07
virtuald's Avatar
RobotPy Guy
You will not be able to communicate with python programs from the LabVIEW dashboard via NetworkTables, as the LabVIEW dashboard is not backwards compatible with NT2 clients, and we haven't upgraded pynetworktables to NT3 yet.
