Go to Post Everyone knows the best way to lose weight is to turn the robot upside down, shake vigourously, and throw away anything that falls out. - Mark Hamilton [more]
Unread 15-02-2016, 18:43
Lesafian Lesafian is offline
AKA: Jeremy Styma
FRC #6077 (Wiking Kujon)
Rookie Year: 2016
Lesafian is an unknown quantity at this point
Issues with LimitSwitch
Hey guys!
I'm having troubles with programming limit switches. We're using a limit switch to stop our arms from going too low. The problem I'm having, is that the limit switch stops the motor, but then the entire robot stops working. Obviously that's a problem with the code. I'm not sure what to do though. I'll paste all of our robot code.
package org.usfirst.frc.team6077.robot;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Counter;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.VictorSP;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class Robot extends SampleRobot {
	// RobotDrive Declaration
	RobotDrive drive;
	Compressor compressor;
	DoubleSolenoid doublesolenoid;
	Solenoid solenoid;
	DigitalInput limitSwitch;
	Counter counter;
	CameraServer server;
	Joystick xboxController;
	VictorSP armMotor, slideMotor, drivemotor1,
	drivemotor2, drivemotor3, drivemotor4;
	final String defaultAuto = "Default";
	final String customAuto = "Autonomous Choice 1";
	final String customAuto2 = "Autonomous Choice 2";
	final String customAuto3 = "Autonomous Choice 3";
	final String customAuto4 = "Autonomous Choice 4";
	final String customAuto5 = "Autonomous Choice 5";
	SendableChooser chooser;
	public void robotInit() {
		drivemotor1 = new VictorSP(0);
		drivemotor2 = new VictorSP(1);
		drivemotor3 = new VictorSP(2);
		drivemotor4 = new VictorSP(3);
		armMotor = new VictorSP(5);
		slideMotor = new VictorSP(6);
		compressor = new Compressor(0);
		compressor.setClosedLoopControl(true);
		drive = new RobotDrive(drivemotor1, drivemotor2, drivemotor3, drivemotor4);
		drive.setExpiration(0.1);
		xboxController = new Joystick(0);
		doublesolenoid = new DoubleSolenoid(0, 1);
		//solenoid = new Solenoid(2);
		server = CameraServer.getInstance();
		server.setQuality(100);
		server.startAutomaticCapture("cam1");
		chooser = new SendableChooser();
		chooser.addDefault("Default Auto", defaultAuto);
		chooser.addObject("Autonomous Choice 1", customAuto);
		chooser.addObject("Autonomous Choice 2", customAuto2);
		chooser.addObject("Autonomous Choice 3", customAuto3);
		chooser.addObject("Autonomous Choice 4", customAuto4);
		chooser.addObject("Autonomous Choice 5", customAuto5);
		SmartDashboard.putData("Autonomous Chooser", chooser);
	public void autonomous() {
		drive.setSafetyEnabled(false);
		String autoSelected = (String) chooser.getSelected();
		System.out.println("Autonomous Mode selected: " + autoSelected);
		switch (autoSelected) {
		case customAuto5:
			break;
		case customAuto4:
			break;
		case customAuto3:
			break;
		case customAuto2:
			break;
		case customAuto:
			break;
		case defaultAuto:
		default:
			break;
		Scheduler.getInstance().run();
	public void operatorControl() {
		drive.setSafetyEnabled(true);
		while (isOperatorControl() && isEnabled()) {
			while (counter.get() > 0) {
                             armMotor.stopMotor();
		//drive.tankDrive(xboxController.getRawAxis(2), xboxController.getRawAxis(5));
		drive.arcadeDrive(xboxController.getRawAxis(1), -xboxController.getRawAxis(0));
		// Lift and lower the arms using the left and right trigger.
		if (Math.abs(xboxController.getRawAxis(3)) > .1) {
			armMotor.set(xboxController.getRawAxis(3));
		} else if (Math.abs(xboxController.getRawAxis(2)) > .1) {
			armMotor.set(-xboxController.getRawAxis(2));
		} else {
		// Move sliding mechanism forwards and backwards
		if (Math.abs(xboxController.getRawAxis(5)) > .1) {
			slideMotor.set(xboxController.getRawAxis(5));
		} else {
			slideMotor.stopMotor();
		// Open and close the claw
		if (xboxController.getRawButton(2)) {
			doublesolenoid.set(DoubleSolenoid.Value.kForward);
		} else if (xboxController.getRawButton(1)) {
			doublesolenoid.set(DoubleSolenoid.Value.kReverse);
		Timer.delay(0.005); //Wait for a motor update time
	public void test() {
I feel like it's a problem with the while loop.
Unread 15-02-2016, 18:50
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Issues with LimitSwitch
You'd be right. What does a while loop do? Yours will continuously be true so it will never break the loop.
What is the point of the counter by the way? There's probably a way to do what you want without this.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 15-02-2016, 19:00
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
help im new to this
I was researching how to program xbox controller to arcade and use one analog stick. Im using talons so what is speed control? and how do i program the xbox controller
public void teleopPeriodic() {
double speedControl = 1;
double joystickLeftY = mXboxController.getRawAxis(1)*speedControl;
double joystickLeftX = mXboxController.getRawAxis(0)*-1*speedControl;
drive.arcadeDrive(joystickLeftY, joystickLeftX);
Unread 15-02-2016, 20:58
AKA: Jeremy Styma
Rookie Year: 2016
It shouldn't. When the lever isn't pressed the value is supposed to be 0, correct?
Unread 15-02-2016, 21:23
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
It is a DIO, thus it returns true or false, not an int.
Unread 16-02-2016, 10:22
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
You never initialize the counter. While that may be ok, I suggest doing that in RobotInit, just in case. At a minimum, I think you have to tell it which DIO channel to watch.
However, it doesn't really do anything in your code. It counts the number of presses, so it should always be >0 after the first press. You either want to see if it is pressed, or not. It doesn't do you much good to count the number of times it is pressed.
Unread 16-02-2016, 18:49
AKA: Jeremy Styma
Rookie Year: 2016
How would this be possible?
Unread 16-02-2016, 22:00
ArchdukeTim
switch = DigitalInput(0)
if switch.get()
    do stuff
Unread 17-02-2016, 15:25
AKA: Jeremy Styma
Rookie Year: 2016
Originally Posted by TimTheGreat View Post
if switch.get()
    do stuff
This does not work.
Unread 17-02-2016, 15:29
This does not work.
Post your code.
Errors?
Doesn't execute the code?
Which DIO port is it on?
Unread 17-02-2016, 16:05
AKA: Jeremy Styma
Rookie Year: 2016
Post your code.
Errors?
It's on DIO port 0. There should be no issues, if you can spot one let me know though!
import com.ni.vision.NIVision;
import com.ni.vision.NIVision.Image;
    // Declarations
	boolean limit1b;
	int session;
	Image frame;
	RobotDrive drive;
	DoubleSolenoid claw;
	Solenoid pusher;
	DigitalInput limit1;
	Joystick logitech3dpro;
	VictorSP drivemotor1;
	VictorSP drivemotor2;
	VictorSP drivemotor3;
	VictorSP drivemotor4;
	VictorSP slideMotor;
	VictorSP armMotor;
	// Autonomous Names
	// Chooser
	public Robot() {
        frame = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_RGB, 0);
        session = NIVision.IMAQdxOpenCamera("cam0",
                NIVision.IMAQdxCameraControlMode.CameraControlModeController);
        NIVision.IMAQdxConfigureGrab(session);
		//Change values later
		logitech3dpro = new Joystick(1);
		slideMotor = new VictorSP(4);
		claw = new DoubleSolenoid(0, 1);
		pusher = new Solenoid(2);
		limit1 = new DigitalInput(0);
		compressor.start();
		chooser.addDefault("Default Autonomous", defaultAuto);
		case customAuto5:
			 /*Only use if have to
			 * Goal: Go through the portcullis & pick up a ball
			 * Note: Values might change as testing is done
			//Drive forwards while lowering arms to default
			drive.drive(1, 0);
			armMotor.set(-0.5);
			Timer.delay(1);
			armMotor.set(1);
			Timer.delay(1);
			drive.drive(1, 0);
			Timer.delay(2);
			drive.drive(0.5, 1);
			claw.set(DoubleSolenoid.Value.kForward);
			Timer.delay(1);
			claw.set(DoubleSolenoid.Value.kOff);
			break;
		case customAuto4:
			/*Hallway autonomous test
			 * Goal: Drive forwards, turn around, come back
			drive.drive(-0.25, 0);
			Timer.delay(3);
			drive.drive(0.50, 1);
			Timer.delay(1.75);
			drive.drive(-0.1, 0);
			break;
		case customAuto3:
			break;
		case customAuto2:
			break;
		case customAuto:
			break;
		case defaultAuto:
		default:
			/*Preferred w/ preferred spawn point
			Goal: Go through the low bar and pick up a ball. */
			//Drive forwards
			drive.drive(-1, 0);
			Timer.delay(0.5);
			drive.drive(0, 0);
			armMotor.set(-1);
			Timer.delay(0.5);
			claw.set(DoubleSolenoid.Value.kReverse);
			Timer.delay(1);
			Timer.delay(1);
			break;
        NIVision.IMAQdxStartAcquisition(session);
	           NIVision.IMAQdxGrab(session, frame, 1);
	           CameraServer.getInstance().setImage(frame);
	          //Forwards limitswitch for slide motor.
	           if (limit1.get()) {
			compressor.start();
			// Move robot using left and right joystick
			//drive.tankDrive(xboxController.getRawAxis(1), xboxController.getRawAxis(5));
			// Lift and lower the arms using the right and left bumper.
			//Arm Motor Test With Triggers
			} else {
				armMotor.set(0);
				slideMotor.set(-xboxController.getRawAxis(5));
			} else {
				slideMotor.set(0);
			} else if (xboxController.getRawButton(4)) {
			//Open and close pushing cylinder
			if (xboxController.getRawButton(3)) {
				pusher.set(true);
			} else if (xboxController.getRawButton(2)) {
				pusher.set(false);
			//Logitech 3D PRO
			if (logitech3dpro.getRawButton(1)) {
				pusher.set(true);
			if (logitech3dpro.getRawAxis(1) > .1) {
			} else if (logitech3dpro.getRawAxis(1) < -.1) {
        NIVision.IMAQdxStopAcquisition(session);
Unread 17-02-2016, 18:27
At the beginning of OperatorControl, you check the limit switch, and stop slidemotor if it the switch is true.
So, make sure the limit switch returns 1 (true) when it is reached, and 0 (false) when it is not.
However, you code continues to execute, and at:
} else {
you set the speed of the motor, without regard to the limit switch.
Unread 17-02-2016, 20:13
AKA: Jeremy Styma
Rookie Year: 2016
So would something like this fix it?
			if (limit1.get() == true) {
			} else if (limit1.get() == false) {
				} else {
Unread 17-02-2016, 20:34
That would work better. I didn't look at your code in detail, so check that your code will move the arm away from the limit switch, or else your arm will permenantly stop when the limit switch is hit.
