Go to Post Nothing like GLR for your inaugural stint as a coach, lemme tell ya. - Kevin Sevcik [more]
Unread 14-02-2016, 15:10
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Jetson TK1 from First Choice Keeps Failing
Hello all,
We are having issues with our Jetson TK1 which received from First choice.
It is running the latest Jetpack 2.0.
It starts up fine, and I can ssh into it to load custom made programs. However, after a while the file system auto mounts itself as read-only.
If I recall correctly, this is automatically done by ubuntu to protect the file system if it detects some error which can make the system unstable.
So this lead me down a faulty hard disk path.
running a few commands I get the following
dmesg | grep "EXT4-fs error"
[ 42.960625] EXT4-fs error (device mmcblk0p1): ext4_mb_generate_buddy:755: group 5, 3697 clusters in bitmap, 3696 in gd
[ 87.527366] EXT4-fs error (device mmcblk0p1): __ext4_journal_start_sb:62: Detected aborted journal
and
sudo fsck /dev/mmcblk0p1 -y -c -f -b -l
/dev/mmcblk0p1: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mmcblk0p1: ***** REBOOT LINUX *****
/dev/mmcblk0p1: 166977/917504 files (0.0% non-contiguous), 2920712/3670016 blocks
Error writing block 32768 (Attempt to write block to filesystem resulted in short write). Ignore error? yes
Error writing block 98304 (Attempt to write block to filesystem resulted in short write). Ignore error? yes
Error writing block 163840 (Attempt to write block to filesystem resulted in short write). Ignore error? yes
Error writing block 229376 (Attempt to write block to filesystem resulted in short write). Ignore error? yes
Error writing block 294912 (Attempt to write block to filesystem resulted in short write). Ignore error? yes
Error writing block 819200 (Attempt to write block to filesystem resulted in short write). Ignore error? yes
Error writing block 884736 (Attempt to write block to filesystem resulted in short write). Ignore error? yes
Not sure where to go from here. It looks like the disk has a hardware failure. This report goes on for miles.
Any recommendation on a fix, or anyone know whom or how I can contact NVIDIA when related to a FIRST item?
Thanks,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 14-02-2016, 15:19
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Jetson TK1 from First Choice Keeps Failing
What happens if you do not load the custom program? Does the Jetson remain stable then?
Unread 14-02-2016, 15:32
Controls Engineer
AKA: Kevin
Thanks for the reply. It continues to fail even if our custom program doesn't run. Our vision program doesn't write out to the hard disk.
We are powering it through the provided wall wart power supply which came with the Jetson.
I have re-flashed it 3 times, using the Jetson 2.0 with the same issue. I have tested our program on another Jetson TK1 which does not fail at all, and runs for hours without auto remounting to a read-only drive.
Unread 16-02-2016, 05:23
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Try running 'fsck' on the root filesystem as root.
# fsck -f /dev/root
When the error occurs, the fs will already be mounted read only.
The -f flag should force a check even though its an ext4 fs.
Unread 16-02-2016, 13:13
We had pretty bad luck with the reliability of the TK1. At one point, we had 2 that flat out refused to boot. I'd be careful if you decide to run this on your robot
Unread 16-02-2016, 13:19
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Ouch...
We have not had those issues. Would highly recommend putting them in a case of some sort though. We also ran ours off of the VRM last year if that helps.
The TX1 is proving to be more of a challenge however... It seems very prone to power fluctuations.
Unread 16-02-2016, 13:33
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Originally Posted by marshall View Post
Ouch...
Do you have CAD for a case or links to one?
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 16-02-2016, 13:52
marshall's Avatar
This is what we used last year:
http://www.thingiverse.com/thing:348473
I threw this together for the TX1 this year and we are using a modified version of it:
http://www.thingiverse.com/thing:1217209
Unread 16-02-2016, 13:55
lethc's Avatar
#gkccurse
AKA: Becker Lethcoe
Could you provide any insight on the choice of using a full enclosure case vs. the 'sneeze guard'?? What would be risked if a more minimal (no side covering) case was used?
Unread 16-02-2016, 14:22
marshall's Avatar
Uhh... crap can get in the side? Nothing really, just what I felt like CAD'ing that day. I do what I want!
Unread 17-02-2016, 07:51
Controls Engineer
AKA: Kevin
# fsck -f /dev/root
Ok. I will try to run that command and report back. Everytime the FS goes read-only, a reboot does not fix. It continues to start-up as read-only. Trying to remount only automatically goes back t read-only. I need to re-flash the drive and then will try again. I was going to try and boot off an SD card.
Thanks for the warnings Tom, any idea what caused your failures? We used a beaglebone in the past with much success, but learned that the rootfs needs to be read-only to avoid intermittent power shutdowns from corrupting the disk. Typically we plan to run our TK1 in read-only mode, but right now, we keep it in write mode because were actively developing on it.
What did you do with the 2 that didn't boot. Did you contact NVIDIA somehow?
Ouch...
I do have it in a case, we modified the 3D printed NVIDIA case, and keep it in there.
Unread 17-02-2016, 12:23
My best guess is eMMC corruption due to yanking the power. Mounting the file system as read only probably makes this better. We didn't really have the cycles to investigate and fix this so we just ended up using another solution.
