Go to Post As in life, the more restrictive the rules, the more creative the 'best' solution will be. - DonRotolo [more]
Unread 02-16-2016, 03:46 PM
Dalas Dalas is offline
Design Lead
FRC #4585 (Husky Robotics)
Team Role: Driver
Dalas is an unknown quantity at this point
Legality of Surgical Tube Flail for Ball Intake
We are currently using an intake that involves surgical tubing connected to a rapidly spinning hex shaft. The intake works well (moderately), but we've started having some worries about its legality per R8 and R9. The flails aren't extremely dangerous (they hurt while spinning, but don't cause bruises) but sound pretty loud.
An example of it in action can be seen here: (we're the robot with long arms)
https://www.youtube.com/watch?v=T3Q2...ndex=1#t=0m37s
You can see a closer view of the intake (not on) here:
https://www.youtube.com/watch?v=mc16NglqYuM
Unread 02-16-2016, 04:15 PM
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Legality of Surgical Tube Flail for Ball Intake
I don't think it is illegal. It may not be the best design solution but I think it'll get past inspection.
Dr. Joe J.
Team #88, TJ2
Unread 02-16-2016, 04:36 PM
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
As long as it doesn't exceed 15" beyond the frame perimeter and follows all rules, I don't see how it would be disallowed. Are you placing any weights at the end of the tubing? I could see that being a safety issue since surgical tubing will dissipate energy pretty quickly, but a weight would have potential to cause harm if separated from the robot.
Unread 02-16-2016, 05:07 PM
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
192 had something similar in 2012. If the rules you're refuring to haven't changed it should be fine. This type of intake was actually really effective at pulling in balls that were bouncing or partially blocked.
Unread 02-16-2016, 05:25 PM
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
We used something very similar to this is 2012 and the legality of it was never questioned.
https://youtu.be/uv7kCd6t5eM
Skip to 1:10
Unread 02-16-2016, 05:31 PM
Design Lead
Team Role: Driver
Great, that's all the information we need to feel safe passing inspection. Thanks to the CD community for always being so helpful!
Unread 02-16-2016, 06:13 PM
RoboChair's Avatar
AKA: Devin Castellucci
1678 used this type of intake inside our robot in 2012 also.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 02-16-2016, 06:30 PM
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to all
while the rules are different, we were passed through with surgical tubing to our events in 2014. Again, the rules are different, so they may not be legal now.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 02-16-2016, 07:32 PM
Gentlemen,
I should remind you that "But it passed at X event" does NOT fly when you're at the current event, AND I'm also obligated to remind you that previous years' rules do NOT apply to this year's rules.
That being said, I would also pass this robot provided that the surgical tubing doesn't go over 15" from the frame perimeter.
