Go to Post ... boundless mentory goodness ... - pfreivald [more]
Unread 15-02-2016, 20:44
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
Help program.
How do you program the POV on the Logitech joystick to move one motor using lab view?
Unread 15-02-2016, 21:24
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: Help program.
On your joystick block, there should be an output for "POVs" which returns an array of integers. Index the first element of that array, and it'll give you the angle that the POV is being pressed. If nothing is being pressed, the value is -1.
Up is 0
Right is 90
Down is 180
Left is either -90 or 270; I don't remember
Head Programmer / Driver
Unread 16-02-2016, 17:45
FRC #5875 (ICE)
Re: Help program.
How do you get to the joystick block?
Unread 16-02-2016, 22:45
Re: Help program.
It's one of the outputs available on the regular Joystick Get Values.
The same vi you use to get the axis and buttons in Teleop.vi.
Unread 17-02-2016, 20:19
FRC #5875 (ICE)
Re: Help program.
How do you program the POV to move a motor up and down? sorry we don't have much experience with lab view.
Unread 17-02-2016, 21:45
Re: Help program.
I don't have a joystick with a HAT in the shop I'm in right now, so I won't be able to test this until tomorrow at the earliest, but this is the idea.
Unread 18-02-2016, 21:00
FRC #5875 (ICE)
Re: Help program.
What is the box at the bottom of the diagram labeled POV and how do you add it?
Unread 18-02-2016, 21:24
Re: Help program.
That's not actually necessary.
It is called an indicator and just gives us a display on the front panel of the live values of POV when you run the code in Debug.
You get it by right-clicking on the wire or output node on the vi and choosing Create->Indicator
Unread 19-02-2016, 17:15
FRC #5875 (ICE)
Re: Help program.
How do you connect the POV to PWM 4?
Unread 19-02-2016, 19:34
Re: Help program.
The snippet Mark posted shows how to control any motor you like. He called it "Motor 1" in his example. You can call it whatever you want in the string wired to the Refnum Get. Just Open it as PWM4 in Begin, and wire the device reference to a Refnum Set with the same name.
Unread 19-02-2016, 20:01
FRC #5875 (ICE)
Re: Help program.
how are you supposed to do that in Begin.vi?
Unread 19-02-2016, 21:25
Re: Help program.
Do it the same way you open any resource.
Name:	put in Begin.png
Unread 19-02-2016, 21:42
FRC #5875 (ICE)
Re: Help program.
Sorry if i came off rude. The program still isn't working, is there anything we may not have done?
Unread 19-02-2016, 22:18
Re: Help program.
There are many things you might not have done. Instead of having us go through all the things detailed in the Screensteps documentation, though, how about you showing us what you have done? Posting your code for us to look at will be a lot faster than going back and forth with "did you do this? and this? and this too?"
Unread 19-02-2016, 22:40
FRC #5875 (ICE)
Re: Help program.
Thank you for all your help. we just forgot to plug in the PWM.
