Go to Post We have not always been a winning team but we have always tried to be a quality team. - WynS [more]
Unread 16-02-2016, 22:05
Team5234 Team5234 is offline
FRC #5234 (The Marauderbots)
Team5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant futureTeam5234 has a brilliant future
Is this legal at competitions?
I apologize if this specific question has been asked in the past. I did search for it. I was asked by a member of our code team to pose this question:
Can we use a rasberrypi to host a website offline (LAN) with an old router ? It would all be offline and use only LAN connection.
Thank you.
Team 5234
Unread 16-02-2016, 22:19
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: Is this legal at competitions?
As long as it does not broadcast any sort of wireless signal and your run everything only over Ethernet ports you should be good.
Unread 16-02-2016, 22:21
Thank you for your reply! Helps a lot.
Good luck to you and your team!
Unread 17-02-2016, 00:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Agreed. All of the (off-field) network restrictions are essentially directed at keeping the 802.11 FMS network clear of interference. Wired connections, bluetooth connections, IR connections, have no FRC-legal issues unless they involve drive teams.
