#16
Re: FRC 95, The Grasshoppers, Build Thread
A close-up of the shooter.
![]() It's a bit... different... than most shooters we've seen before. We've setup the first 'booster' stage (3/4 of the length) to ramp up in speed as it feeds into the 'firing' stage, which spins considerably faster. Prototype testing has been quite promising. |
#17
A few pictures from today:
The shooter is nominally populated with belts and rollers and stuck on the robot! ![]() How he'll be able to fit under the low bar. ![]() Wiring is about 70% there, enough for a power-up test! ![]() We're currently trying to get code on the Athena (we refuse to call it the "Roborio"), which always seems to have some growing pains. We'll get there... |
#18
Are you planning to intake from both sides? Is there any significant advantage, that your team saw, to that strategy (if you are indeed capable of intaking from both sides)?
#20
Though your point is well-taken. The versaplanetary guide is to be taken quite seriously! |
#21
A team after my own heart.
#22
Man, I love 95's robots. You guys always put out something beautiful and unique.
#23
I love seeing this thread every year. 95 is always evolving and improving. Good luck in 2016!
#24
Thank you! It is what we strive for, at least in baby steps. And good luck to the Rocketeers! |
#25
RE the dual lock on the electronics - you sure that'll hold everything tight when crossing defenses?
Looks good again this year man. |
#26
And thanks! |
#27
Wow, that's a really creative design in a game with many similarly designed low bar bots. We'll be seeing you guys at Granite State, good luck!
#28
Started our drive-train burn-in only to have the burn-in go a little too literal for us...
Side plate off to investigate: ![]() Yeah... had some rubbing chain tensioners... ![]() Milled them down, reassembled, and tried out some defenses. Moat Low Bar Did some crossing exercises, everything looked good, until... ![]() Weirdest chain failure I've seen, and the only one I've ever had on a 95 robot. Master-link was good, fractures are on opposite sides of the chain loop, tensioners were installed and slack(ish), and our nominal FoS is around 4 or 5. Bizarre... Last edited by JamesCH95 : 02-17-2016 at 02:29 PM. |
#29
The shooter is now wired up and functional!
Here is the firing stage of the shooter spooling up to full-speed. It is powered by 2x RS775Pros with 1:1 versa planetary transmissions. All belts are designed 'perfect' center to center. Shafts are 1/4in steel D-shafts supported by bearings rated to ~50krpm. Kovaka firing stage spool-up Here is a test shot with the booster stage feeding the firing stage. Kovaka test shot Two of three subsystems down... only the shoulder to go... |
#30
Sweet!
