Go to Post DONT USE ROBOTS FOR EVIL!!! - Cooley744 [more]
Unread 15-02-2016, 20:36
Cobra Commander's Avatar
Cobra Commander Cobra Commander is offline
FRC #0498 (Cobra Commanders)
Cobra Commander is on a distinguished road
Question Grip persist after Robot reset
Is there a way to make Grip stay and run automatically after the robot restarts?
It works fine if I deploy it and use it without power cycling the robot.
If not, having to redeploy at the beginning of each match would most likely count as a delay penalty.
Unread 15-02-2016, 20:39
robert1356 robert1356 is offline
AKA: Robert Palmer
FRC #3824 (RoHAWKtics)
robert1356 is an unknown quantity at this point
Re: Grip persist after Robot reset
You need to add code to your robot code to start GRIP. This is documented on the GRIP github Wiki
Unread 15-02-2016, 22:05
For anyone else who didn't know this. Here is the link to the article.
https://github.com/WPIRoboticsProjec...EW-FRC-program
Unread 16-02-2016, 00:37
After looking at the wiki I'm still having trouble. I am having a permission denied error.
We are using Java.
I am trying to start "/home/lvuser/grip.jar" is this the right file?
The code
try {
        	 new ProcessBuilder("/home/lvuser/grip.jar").inheritIO().start();
            SmartDashboard.putString("Grip", "Started");
            System.out.println("Grip Process Started"); //Print to RioLog
        } catch (Exception e) {
            SmartDashboard.putString("Grip", "Is Bad News");
            e.printStackTrace();
		visionTable = NetworkTable.getTable("GRIP/myContoursReport");
The Error
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1042)
 	at org.usfirst.frc.team498.robot.Robot.<init>(Robot.java:23)
 	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
 	at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
 	at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:204)
 	at java.lang.UNIXProcess.forkAndExec(Native Method)
 	at java.lang.ProcessImpl.start(ProcessImpl.java:134)
 	... 8 more
 platform: /Linux/arm/
 	at org.usfirst.frc.team498.robot.VisionManager2016.<init>(VisionManager2016.java:26)
 	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
 Caused by: java.io.IOException: error=13, Permission denied
 	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1023)
 java.io.IOException: Cannot run program "/home/lvuser/grip.jar": error=13, Permission denied
 	at java.lang.Class.newInstance(Class.java:433)
 NT: server: client CONNECTED: 10.4.98.147 port 49582
 	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
 	at java.lang.UNIXProcess.<init>(UNIXProcess.java:187)
Unread 16-02-2016, 17:21
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
We are using Java.
Check out the wiki page. You actually just need to run "/home/lvuser/grip", which is a wrapper script that kills previous instances of GRIP and runs it with the appropriate command line args.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 16-02-2016, 20:21
I had tried that originally.
This is the error I get with the copy and paste initialization.
➔ Launching «'/usr/local/frc/JRE/bin/java' '-jar' '/home/lvuser/FRCUserProgram.jar'»
 java.io.IOException: Cannot run program "/home/lvuser/grip": error=2, No such file or directory
 	at org.usfirst.frc.team498.robot.Robot.robotInit(Robot.java:23)
 	at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)
 	... 3 more
 	at edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:124)
 Caused by: java.io.IOException: error=2, No such file or directory
Is there possibly a step I am missing in the deploying process from the GUI part of GRIP?
Unread 16-02-2016, 20:22
FRC #0237
Do you have an old version of GRIP? If so, you should upgrade to v1.2.0 and deploy again
If not, can you post the log from the deploy console?
Unread 16-02-2016, 23:10
Yep! I was still using an old version. Thank you for the help. All appears to work now.
