Go to Post According to Clarke's third law, I believe their entire robot works by magic. - dtengineering [more]
Unread 16-02-2016, 22:42
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
775 pro performance and break in
using a 775 pro for our shooter. we are getting poor performance out of it. pulling 40 amps at 11.5 volts(measured via pdp) and getting smoking hot just free spinning banebots 3 7/8 wheels with a 2 to 1 reduction via belts all running on thunder hex in vexpro bearings, belt center distance was set in cad so they are appropriate tightness. the wheels spin with little to no resistance by hand according to the spec sheet the motor should be somewhere around 12500 rpm, i did not have the ability to measure the rpm at the time but it was no where near that. we did no break in just straight to the shooter for test shots. can the lack of break in cause the poor performance or is there something i am missing.
also whats everyone's opinion on breaking them in. i know some rc people like to break in there 775s at 3v in water for 20 mins
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 16-02-2016, 22:43
cmwilson13's Avatar
Re: 775 pro performance and break in
i have heard that high load full power runs on a new motor can pit the brushes, i wonder if that was our problem
Unread 16-02-2016, 22:50
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We had issues with the 775pros so much so that we actually switched over to mini-cims.
Basically they were slipping from the versa planetary collar and we preferred to use an actual machine key.
Unread 16-02-2016, 22:56
cmwilson13's Avatar
we dumped the versa in the first hr it pulled 60 amps using the versa 1 to 1.
we press fit a hex shaft onto the 775 and used the versa case to mount the motor with the guts removed. dropped to 40 amps just with that change
Unread 16-02-2016, 23:02
It can be deceiving. There may be more resistance than you imagine.
Can you remove the motor and run it with no load and see what the free current is?
Unread 16-02-2016, 23:26
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We too had some issues with our 775Pro motors and the versaplanetaries... Everything needs to be just right to get the free current down to 10 Amps or less. We are running dual vertical axis shooter, 3:1 with our VPs and dual 3.5 inch Colsons per axis. We had to really crank down on the clamp for the motor shaft to keep it from spinning.
Unread 16-02-2016, 23:28
cmwilson13's Avatar
free current was somewhere around 1 to 1.5 if i remember right
Unread 17-02-2016, 00:19
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
We are not using the VP's, using GT2 3mm belts and its fairly quiet with great performance atm. Also using press fit pulleys so no slippage!
R.C.
MadTown Robotics Team 1323
Unread 17-02-2016, 00:25
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
We're using 775pros with VersaPlaneteries in multiple places with no problem really (3:1, 30:1, and 100:1). The 3:1 goes into a 1:1.2 driving 4" AndyMark Stealth Wheels. At about 7k RPM (at the wheels), we're seeing about 10A current draw, which is right in line with the spec sheet. It gets pretty hot after 10 minutes of continuous usage, but that is completely reasonable. I can check with our students, but I don't think they did anything particularly special when putting together the planeteries.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 17-02-2016, 00:26
You probably have a lot more friction in your shooter setup than you realize.
40 amps @ 11.5 volts is 460 watts going into the motor, roughly 190 of which are being turned into heat.
