Go to Post Eh, typical FIRST team, take something awesome and make it even better. - rsisk [more]
Unread 17-02-2016, 01:50
Peter Johnson Peter Johnson is online now
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: SPI Write Limitation
Originally Posted by gerthworm View Post
Seems like it. The bit of research I've done on this seems to indicate SPI is implemented on the FPGA, which I assume means any buffers are of fixed length. What those lengths are, however, I'm not really sure....
Yes, it's a hardware limitation. Per the Zynq documentation [1], the SPI read and write FIFOs are 128 bytes deep. This matches the behavior you're seeing. Conceptually, functionality could be added to wpilib to do the outer loop for longer writes, but I think this case is rare enough (and there's multiple ways to do it, e.g. use interrupts to determine when to continue filling the FIFO, or periodically check), that it's better left to the user code to implement.
[1] http://www.xilinx.com/support/docume...q-7000-TRM.pdf, section 17.2.4.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 21-08-2016, 16:46
s5511's Avatar
s5511 s5511 is offline
FRC #5511
s5511 is an unknown quantity at this point
We are trying to control the AdaFruit DotStars through the SPI bus, too, except we are using LabVIEW. Which ports on the roboRIO did you guys connect the dotstar to?
NC Rookie All Star, Rookie Highest Seed 2015
NC THOR Winner 2015
NC Guilford County Winner and Creativity Award 2016
Unread 21-08-2016, 19:19
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Actually, we ended up using both at one point. We started by using the dedicated 10-pin port on the top, then we switched to the port that's on the custom expansion port in the middle.
I'm not familiar with sending bytes in labview. However, I know in java it was just a single initialization parameter to say which SPI port to use. Everything else was the same.
Also as indicated in this thread, we did have to chunk the send data into 128-length bytes to get it to work nicely.
