Re: Reading Published Values from External Application
Depending on how it was stored, it is either in /SmartDashboard/GRIP/Contours or in /GIP/Contours. The easiest way to see is to use the variables tab of the dashboard or another table viewer to compare the variable name. And remember that they are case-sensitive too and need to be read as the correct type ( number as number, string as string, etc.)
Greg McKaskle |
