Go to Post And that's part of the game... The field is never reset! Muhahaha! - nighterfighter [more]
Unread 16-02-2016, 23:29
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
connecting Versaplanetary gearbox
Pardon the stupid question in advance. Almost-lone (and non-engineering) mentor trying to help kids figure stuff out, here...
We have some Vex versaplanetary gearboxes attached to a couple of bag motors to drive two mechanisms. They have 1/2" hex shaft outputs, and we wanted to connect them to a longer shaft that stretches across the body of the robot.
However, hex shaft couplers are totally out of stock at Vex (as is everything else). Is there some other way to connect the shafts, or someplace else to order a shaft coupler?
Feeling really dumb, here. Thanks for any help.
Unread 16-02-2016, 23:32
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: connecting Versaplanetary gearbox
In a pinch I've used VEX hex spacers as a shaft coupler. You can use shaft collars or a bit of glue to hold it in place. http://www.vexrobotics.com/acetalspacers-vexpro.html
2016: FRC 865 Mentor
Unread 16-02-2016, 23:43
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
That's exactly what we're doing, now (plus a layer of duct tape), and we're afraid it won't hold, but maybe it will. How much of a load could it take? This is for a pivot arm that doesn't have too much of a load on it.
Thanks for the feedback!
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
I suggest ordering a few colson live hubs from Vexpro and putting some setscrews in. http://www.vexrobotics.com/vexpro/mo...sonhubs-g.html
We have one hex to hex coupler we are not using.
http://www.vexrobotics.com/vexpro/ha.../217-4008.html
Also one of the colson live hubs.
We went a different direction.
PM me your address and I will put both in the mail in the morning.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 16-02-2016, 23:48
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
You could use one of these -
https://www.andymark.com/Hub-p/am-0096a.htm
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 17-02-2016, 00:06
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
Thanks for your kind offer! I recall that we have a couple of the AndyMark hubs that Chris Fultz suggests, so I will have someone check that first thing tomorrow. If we don't have anything that works, you'll be hearing from me.
I appreciate all the feedback. I was just thinking that we were probably missing something obvious.
Unread 17-02-2016, 06:57
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We have had good luck with cutting off a 1/4-20 bolt and screwing them together and using a shaft collar to keep them from spinning off.
Unread 17-02-2016, 07:59
BSV,
Duct tape does not a fastener make.
Unread 17-02-2016, 08:03
daliberator's Avatar
daliberator daliberator is offline
Ace Machinist
AKA: Henry O'Callaghan
FRC #4536 (MinuteBots)
daliberator will become famous soon enoughdaliberator will become famous soon enough
As part of our climber mechanism, we just cut the adapter off of a 1/2" hex deep wall socket. It seems to work fine. I'm sure you could find one at any hardware or automotive store.
4536 Team Captain
www.minutebots.org
Unread 17-02-2016, 08:58
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Clever.
Unread 17-02-2016, 09:49
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Other option is to use the 1/2 round output on the Versaplanatary, turn~ half an inch of the Hex shaft to .500 round on a lathe, and use standard and common round coupler.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 17-02-2016, 10:03
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
If you or someone you know has access to a 1/2" hex broach, you could make your own out of a piece of 3/4 or 1" aluminum bar and a couple of setscrews. You could also make one without the hex by drilling and boring (for concentricity) a piece of 3/4 bar. Setscrews could lock it in place and transfer torque.
My views do not necessarily reflect those of FIRST Robotics
George Chisholm
2003-2015 Founding Mentor FRC 1334 The Red Devils
2011 Woodie Flowers Finalist, Waterloo Regional
2015-Founding Mentor FRC 1360 Orbit Robotics
Unread 17-02-2016, 10:04
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
BSV,
But, but, but.... the MythBusters use it for everything!
Haha, no kidding. That was only temporary.
Unread 17-02-2016, 10:06
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
Oh, this is a nice idea, too. Backup plan if the hex hubs don't turn up. We'll find out this evening.
We unfortunately do not have any lathe capabilities (yet. I am hoping to change this if we can ever attract any real mentors into the fold.)
Unread 17-02-2016, 10:12
GCarnes's Avatar
GCarnes GCarnes is offline
FRC #5150 (Hybrid Hornets)
Team Role: Driver
GCarnes is just really niceGCarnes is just really niceGCarnes is just really niceGCarnes is just really nice
Last year my team extended the versaplanetary output shafts by threading another piece of thunderhex shaft onto the end and using a hex collar over the seam to keep it all together. Worked great and held up the whole season on both sides of our elevator.
