Go to Post This is still about fun. Remember that. - Koko Ed [more]
Unread 17-02-2016, 12:23
FRC Warrior FRC Warrior is offline
FRC #4169
FRC Warrior is an unknown quantity at this point
Are these bumpers illegal?
http://imgur.com/zA3S6g2
Unread 17-02-2016, 12:31
Doiteain's Avatar
Doiteain Doiteain is offline
That tall guy over there
AKA: Cuyler
FRC #5026 (Iron Panthers)
Doiteain is infamous around these partsDoiteain is infamous around these parts
Re: Are these bumpers illegal?
I think we're going to need more pictures to really tell.
Initial instinct is no, because of the gaps in support, but could you post something of the entire area?
Also, where is your frame perimeter designated at?
Unread 17-02-2016, 12:39
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Right off the bat, the first thing that comes to mind is R26:
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-9). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERMIETER. Additionally, any gap between the backing material and the frame:
A. must not be greater than ¼” deep, or
B. not more than 8 in. wide
Emphasis mine. Based on just that, I would say no, your bumpers are not legal currently.
Once you fix that, I would suggest posting additional pictures to ensure that your bumpers satisfy the rest of the requirements in Section 4.7 of the 2016 Game Manual.
Unread 17-02-2016, 12:40
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I see two big legality issues in this picture (which isn't to say there aren't more that I don't see).
First, your bumpers are not supported on the ends- see R26. That means both ends of each bumper segment. We don't want any bumpers that are cantilevered, as that significantly increased the chance of the bumper breaking under impact.
Second, without something that extends into the corner of your bumper, your frame perimeter becomes poorly defined for your bumper design- essentially, there another "side" to the robot right in the corner, stretching on the diagonal between the two supports. That "side" is not properly backing the bumper at all.
Other possible issues that I can't tell from the photo:
- Bumper length must be at least 8". If those are 8" wheels, then it looks like the bumpers are about 8"
- I am assuming in this picture that the stabdoffs are permanently attached to the robot. If, instead, they are permanently attached to the robot, then you need some major redesigning to do. The wood must be on the frame perimeter and backed/supported by the frame/structure of the robot, not stood off of it like that.
2016: Lake Superior WFFA
Unread 17-02-2016, 12:42
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Originally Posted by FRC Warrior View Post
Absolutely not. There is a lot wrong with them. The most obvious is the frame does not back up the bumpers from the corner and extend in 8".
edit: My goodness Stratis is fast...
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 17-02-2016, 12:44
philso philso is offline
FRC #2587
It may be the angle the photo is taken at but it looks like the mechanism at the bottom right corner of the photo may stick out past the inside surface of the bumpers and it does not look like it retracts.
Your frame perimeter should be totally enclosed by the inside faces of the bumpers. Read the Game Manual carefully to understand the requirements for any spacing, support points, gaps in the bumpers etc. Ask questions on this forum if you are still not sure about your interpretation of the bumper rules. You are not alone if you feel confused.
Unread 17-02-2016, 13:12
FRC #4169
It does retract, it's on silders
