Go to Post If you do mentor FIRST, be an asset to your team, but know that your students will admire you all the more if you set an example and finish your own homework. - Eugenia Gabrielov [more]
Unread 16-02-2016, 17:02
X_Machina_4645 X_Machina_4645 is offline
FRC #4645
X_Machina_4645 is an unknown quantity at this point
Spybox limitations and Bumber questions
Our first question is what are the limitations inside and between spybox and the alliance zone. Our question pertaining to bumbers is if we are allowed to raise the bumbers? and if we can change/cut the materials for bumpers?
Unread 16-02-2016, 17:21
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Spybox limitations and Bumber questions
No guns, smoking, or drinking allowed
See G4, G14, G29, G37, 5.5.9
No further restrictions.
There is no requirement that the bumpers remain in the same position in the bumper zone. However, the robot must be in compliance with the bumper rules at all times, and the bumpers may not be articulated.
you can change an cut materials all you want, as long as they meet the bumper rules.
Unread 16-02-2016, 17:51
FRC #4645
Ok I need to clarify the questions. By limitations in the spybox, I meant whether or not the person in the spybox can communicate with their alliance members if the form of communication is not wireless/electronic...for example: a mirror or a 'cup and string' (yes..seriously). Also, we wanted to know if the person in the spybox can control the robot with a wired controller since no wireless signals are allowed. Next, by cutting the materials I meant if we are basically allowed to cut the sides/corners of the bumpers to have a smaller area, this way our robot can fit between the guard rails on the batter.
Unread 16-02-2016, 18:04
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
I am pretty sure there are rules regarding the size of your driver station. Last year it had to stay within the space above the table so I think the same will apply this year.
IE: you cannot have a wire connecting your spy's controller to the laptop.
SolidWorks CAD
AutoCAD
Java
Unread 17-02-2016, 13:41
No. The Human Player CANNOT contact a robot in the field. It would also violate the 15 inch rule for the robot.
The rules prevent physical and electronic communications between the Spy Box and Castle. "Physical" being any device that has any part physically outside of the Spy Box or Castle. Note: Visible light is not considered physical nor electroinc.
American Sign Language is fine. So is Morse code with a flashlight, signal flags, etc.
http://www.chiefdelphi.com/forums/sh...d.php?t=141244
Unread 17-02-2016, 13:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
You can only use a flashlight if it's unpowered. There is a specific Q&A about this, and it had a humorous response. Yet for some reason searching the Q&A for 'mutton','flashlight','spy', or 'power' doesn't seem to find it...
GitHub
Unread 17-02-2016, 14:02
Here it is:
https://frc-qa.firstinspires.org/Que...ce-under-5-5-9
I guess I'll have to use my naturally glowing personality for the source of light.
