Go to Post Now repeat after me: it is just a game. It is just a game. It is just a game... - dlavery [more]
Unread 17-02-2016, 10:17
FRCTeam3293 FRCTeam3293 is offline
FRC #3293
FRCTeam3293 is an unknown quantity at this point
Help with Labview please
We trying to assist a rookie team with Labview. They are simply trying to control one motor using a victor SP. Can someone offer a suggestion? The entire message is below:
"We had it yesterday, but sadly it did not work this is what we did. We put the program on the begin VI, not sure if that’s where it goes. It allows me to run the main VI, but I get an error in the driver station that says “The refNum trying to get does not exist in the refNum Registry”."
Unread 17-02-2016, 10:30
Re: Help with Labview please
The error is probably because of the incorrect Joystick reference in Begin.vi
You can't use a Joystick to select the deadband in Begin.vi
They have to use a different method to choose true/false or relocate the Motor Open elsewhere to happen after Begin.vi has completed executing and reliable Driver packets have begun to arrive and be processed.
Begin.vi just holds declarations (Opens) of devices that will be used elsewhere.
You can't actively use devices in Begin.vi.
They are trying to use a Joystick device that hasn't finished the process of being declared yet elsewhere in Begin.vi.
And Begin.vi only gets called once on robot code startup, and until the joysticks are defined there is most likely not even a valid driver station packet at the time Begin.vi runs to pass along any Joystick value.
Unread 17-02-2016, 14:03
FRC #3293
Thanks Mark. Very helpful.
