Go to Post Well I guess that's better than some teams idea of team bonding which would be taping a wayward freshman to the wall with duct tape. - Koko Ed [more]
Unread 17-02-2016, 16:10
Steph342's Avatar
Steph342 Steph342 is offline
FRC #5508 (Career Magnet Academy)
Steph342 is an unknown quantity at this point
Adding air between matches
We plan to use a lot of air during the match and will have many air tanks on the robot. Is there an easy way in which to fill the air back in the tanks after the match? We will also have a compressor on board during the match.
Team #342 Alumni
Team 5508 Mentor
Unread 17-02-2016, 16:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Adding air between matches
Sure, run the robot while you're in the pits and queuing. We've been doing this for years.
Unread 17-02-2016, 16:15
Steph342's Avatar
I was just worried that between elimination matches we may not have time to allow it to run enough to fill it up. Was not sure if we could have a port to but air in the tanks with an off robot storage tank.
Team #342 Alumni
Team 5508 Mentor
Unread 17-02-2016, 16:19
ZamericaZ's Avatar
ZamericaZ ZamericaZ is offline
AKA: Eric Mazza
FRC #0503 (Froge Force)
Team Role: Operator
ZamericaZ is an unknown quantity at this point
Like MrForbes said you can enable your robot in between matches so long as it is connected via Ethernet to your laptop, I recommend charging them before switching out your battery to maximize the voltage next match.
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
Only one compressor can provide compressed air for your robot (R79). This means that if you have an on board compressor, you can not have an off board compressor as well.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 17-02-2016, 16:22
Steph342's Avatar
Thanks everyone
Team #342 Alumni
Team 5508 Mentor
Unread 17-02-2016, 16:23
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
I believe in the manual under the tournament section there is a minimum time guaranteed before your next match. I want to say this is 6 minutes but without the manual in front of me I will leave you to check my thought. Summarizing the logistics it is up to you to create a system that can be filled in the amount of time you get between matches during finals as this is typically when you have the least amount of time before the next match. If your time needed is greater than the time you get between final matches then you may be hurting heading into that match. All other time between matches typically should be greater and on the order of 20 minutes or more. So design for the minimum time and you will always be golden.
Unread 17-02-2016, 16:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Your only legal option is to turn the robot on in the pit, tether it up, and wait for the tanks to fill.
R79 Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications must not exceed nominal 1.10 cfm flow rate @ 12VDC.
Unread 17-02-2016, 16:29
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Could you, theoretically speaking, use the robot earlier in the competition to fill up additional storage tanks, or a singular large tank, that could then be used to top off the robot in eliminations?
The robot's on-board compressor would have filled up those tanks (or tank), meaning the air was provided by a single compressor, meaning that you would still have all air provided by the one compressor, and the compressor would maintain a lower temperature during eliminations due to not needing to run between matches as well as during them.
EDIT: Jon Stratis quoted the relevant passage. This would not be permitted.
It's not done until it's overdone!
Unread 17-02-2016, 16:30
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
And don't forget about R81 (emphasis added)
“Stored” air pressure on the ROBOT must be no greater than 120 psi. No stored air pressure intended for the ROBOT may be located off-board the ROBOT.
2016: Lake Superior WFFA
Unread 17-02-2016, 16:49
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Cannot store pressurized air for later use on the robot
R81 “Stored” air pressure on the ROBOT must be no greater than 120 psi. No stored air pressure intended for the ROBOT may be located off-board the ROBOT.
You must also vent the left over pressure prior to removal from the field.
Take this into account. Might be a good idea to time how long it takes to fill the system from empty.
We have been charging our pneumatics from the pits and in queue for years with no issues. We have been able to fill 4 high pressure and two low pressure tanks in the time spent in queue. If you need more than that time you might want to look and minimizing some air usage.
Good luck this season!
Aloha
edit: sniped by Jon
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 17-02-2016, 18:17
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
FYI: The KOP Compressor is rated for a 10% (approximately) Duty Cycle. 6 Minute run time every 60 minutes.
If you need to run it more than that, you need to get a higher rated compressor. Viair makes the KOP compressor. The Viair IG line is rated for 100% duty cycle. However, it costs 4 times more, and weights 3 times more.
http://www.viaircorp.com/330C-IG.html
Note: The CFM is 1.06 at 12 volts, below the 1.10 CFM limit. The 24 volt version does exceed the FRC limit.
During qualifications, duty cycle should not be a problem. During eliminations, it could be a problem if you are using a lot of air.
Unread 17-02-2016, 20:11
MrForbes's Avatar
AKA: Jim
The rated duty cycle of the little compressor assumes that it does not have any additional cooling...we've found that using one of the small fans that is allowed on the robot for cooling speed controllers, will also work to cool the compressor sufficiently to run it at 100% duty cycle for a match, or longer. Without the cooling fan, the compressor will get so hot that it can even melt the plastic air tubing connected to it! not good.
YMMV.
Unread 17-02-2016, 21:29
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Originally Posted by TikiTech View Post
...You must also vent the left over pressure prior to removal from the field.
I might be missing it, but we've never done this and have never been asked to do this. Care to cite a rule? I searched and came up empty...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 17-02-2016, 21:32
There isn't one.
Now, as a matter of SAFETY, it may be determined either way as to whether it's safer to vent the air or to leave it in. I can think of one or two applications where it might be safer to vent, possibly, but stuff is more likely to stay put when there's air in the system.
