Go to Post If you pay attention to every nut job on ChiefDelphi, you'll never reach a decision. - JesseK [more]
Unread 11-02-2016, 17:32
SteveWozniakek SteveWozniakek is offline
FRC #1369
SteveWozniakek is an unknown quantity at this point
Flipping an image in NIVision
With NIVision I am trying to flip a camera image upside down. I currently have it as an Image type and do not see a NiVision method for rotating or flipping the image. Does anyone know how to flip the camera image in NIVision so I can send it to the CameraServer?
Unread 13-02-2016, 10:51
koreamaniac101's Avatar
koreamaniac101 koreamaniac101 is offline
Founder and Team Leader
AKA: Soohan Kim
FRC #5938 (Razor Steel Robotics 4-H Club)
Rookie Year: 2016
koreamaniac101 is an unknown quantity at this point
Re: Flipping an image in NIVision
Team 5938 is also looking for a solution to this as well. We have our Microsoft Lifecam mounted upside-down, and our drivers don't exactly like to go through the terrain with the floor on top.
Unread 13-02-2016, 15:55
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
soundfx is an unknown quantity at this point
Have you looked at the imaqFlip method in NIVision?
Unread 17-02-2016, 06:37
FRC #1369
Yes I found the solution. I'll post a snippet later today for flipping it properly. Thanks for help though!
Unread 17-02-2016, 16:35
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Can you please post the code that you used to do this? My team has mounted the camera upside down, and I need to flip the image in code. I couldn't find any documentation on NIVision, and I would appreciate any help.
I am using Java and this is my current command, which is set to run while the robot is disabled. It currently doesn't correctly send an image to the SmartDashboard and throws and exception occasionally.
package org.usfirst.frc.team1939.robot.commands.camera;
import org.usfirst.frc.team1939.robot.Robot;
import com.ni.vision.NIVision;
import com.ni.vision.NIVision.FlipAxis;
import com.ni.vision.NIVision.Image;
import com.ni.vision.NIVision.ImageType;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.vision.USBCamera;
public class CameraUpdater extends Command {
	private USBCamera camera;
	private CameraServer server;
	public CameraUpdater() {
		requires(Robot.camera);
	@Override
	protected void initialize() {
		this.camera = new USBCamera("cam0");
		this.server = CameraServer.getInstance();
		this.camera.startCapture();
	@Override
	protected void execute() {
		Image source = NIVision.imaqCreateImage(ImageType.IMAGE_RGB, 0);
		this.camera.getImage(source);
		Image dest = NIVision.imaqCreateImage(ImageType.IMAGE_RGB, 0);
		NIVision.imaqFlip(dest, source, FlipAxis.CENTER_AXIS);
		this.server.setImage(dest);
	@Override
	protected boolean isFinished() {
		return false;
	@Override
	protected void end() {
	@Override
	protected void interrupted() {
Unread 17-02-2016, 19:35
FRC #1369
Your code is good but center axis needs to be vertical axis( I lied your knit cam wrong here's a snippet)
camCenter = NIVision.IMAQdxOpenCamera("cam1", NIVision.IMAQdxCameraControlMode.CameraControlMode Controller);
camRight = NIVision.IMAQdxOpenCamera("cam0", NIVision.IMAQdxCameraControlMode.CameraControlMode Controller);
curCam = camCenter;
camera = "center";
// Img that will contain camera img
frame = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_ RGB, 0);
// Server that we'll give the img to
server.setQuality(50);
server.setSize(666);
Unread 17-02-2016, 19:51
3205patriots 3205patriots is offline
FRC #3205
3205patriots is an unknown quantity at this point
I had this problem too and all you need to do to flip the image 180 degrees is
Image frame = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_ RGB, 0);
NIVision.imaqFlip(frame, frame, FlipAxis.HORIZONTAL_AXIS);
