Go to Post Uh. Oh. Wildstang is simple and has a swerve. Where have I seen that before? - EricH [more]
Unread 17-02-2016, 21:17
Team5860-Alex Team5860-Alex is offline
FRC #5860
Team5860-Alex is an unknown quantity at this point
Critical Talon Srx help needed
This is our rookie year and programming is off to a great start however we want to use encoders to do a series of commands. We have tried our best efforts, referred to the software manual and still cant get it to work. We do have an encoder read out and can find/reset the encoder position, however in teleop we cant get the motors to move at all. We are using digital quadrature encoders on the versa planetary gearboxes right to the CAN talon srx's. If we could get some code or code pictures to help out that would be much appreciated. the examples werent much success either
Unread 17-02-2016, 21:19
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: Critical Talon Srx help needed
Are you using PID control or percent control?
Here's the Talon SRX software reference manual. There is some example code in there for whatever you are doing.
https://www.ctr-electronics.com/Talo...e%20Manual.pdf
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 17-02-2016, 21:34
FRC #5860
PID
Unread 17-02-2016, 21:35
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Originally Posted by Team5860-Alex View Post
PID
Do you have any code?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 17-02-2016, 21:49
FRC #5860
this is the code
https://www.dropbox.com/s/aid95e1i31...87%29.png?dl=0
Unread 17-02-2016, 22:24
Matt-T-FRC Matt-T-FRC is offline
Electrical Engineering Student
AKA: Matt Tisovic
FRC #6181 (Northwest State Cryptic Cyborgs)
Matt-T-FRC is an unknown quantity at this point
Can we see a snapshot of your Begin.vi and Telop.vi please
Unread 17-02-2016, 22:27
AKA: Nick Schatz
I'm not very familiar with LabVIEW, but I'll try to help as much as I can. What are the PID values you are using with the Talon? You can try increasing P until you see the motor move (safely). I've found that the Talon self-test is pretty helpful for checking problems.
You have the quad encoder hooked up to the talon via the breakout board, yes?
Unread 17-02-2016, 22:29
FRC #5860
Yes using breakout board
PID Values
https://www.dropbox.com/s/dvhe5a325z...10%29.png?dl=0
Begin
https://www.dropbox.com/s/wzamoeuelc...88%29.png?dl=0
Teleop
https://www.dropbox.com/s/1o918lpwrf...89%29.png?dl=0
Unread 17-02-2016, 22:41
AKA: Nick Schatz
Those are some seriously huge PID values. P should be between 0 and 1 in most cases. I would start tuning with just a P value and no I/D, which you can add later if you need the stabilization.
The Talon SRX software reference manual has some good tips on PID tuning. You can use the self-test button to determine error, and calculate your initial P value based on that.
Unread 17-02-2016, 22:43
AKA: Matt Tisovic
Alright, that's a great start. Your Begin.vi you need everything to the right of the loop in your Telop.vi minus the driver station start communication. In your Telop.vi, you need everything inside the while loop except for the timer. Besides that, have you attempted to run this program at all on your robot?
Name:	Can Talon Encoder Image.png
Unread 17-02-2016, 22:53
FRC #5860
Yes we ran it but nothing happened, is it an automatic process or should we assign this to a button?
Unread 17-02-2016, 22:59
AKA: Matt Tisovic
It should be assign to a button with the number of rotations that you would like the motor to turn.
Unread 17-02-2016, 23:10
FRC #5860
Like so??
https://www.dropbox.com/s/81gj2e6wt4...12%29.png?dl=0
Unread 17-02-2016, 23:35
AKA: Matt Tisovic
Unless your resetting your PID in telop, this should be all you need to control that motor
Name:	Talon SRX Example.png
Unread 17-02-2016, 23:46
FRC #5860
Nope still nothing
