Re: Charged system during inspection?
Please note T18:
I generally will do sizing first.... so I just ask that the robot be placed into its starting configuration. If that requires the robot to be pressurized I would ask that it be that way. After that is finished, you would dump your pressure and disconnect everything else that had to be connected. I would always ask for your team to put the robot in its starting configuration as if you had just put it on the field. It is at that point in the competition that it has to fulfill the frame perimeter rule. Just do what the inspector asks... we will work with you to make things safe. If you are under pressure or any item on your robot has stored energy, make sure your inspector knows. |
As a general safety rule. Do not assume a machine is in a low energy state unless you have verified that. In industry it is called lock out tag out. In FRC in is called "don't stick your hands in a strange robot"
Slightly off-topic but related cautionary comment:
Relying on a charged pneumatic system to keep your robot in its legal starting configuration can be risky. One extreme scenario has occurred when robots are on the field, ready for the first match of the day, and a visiting dignitary makes a longer-than-anticipated speech.* I have seen teams DQ'd when their pneumatically constrained appendages sagged out of starting configuration after 20+ minutes sitting idle during opening ceremonies. A slow air leak that would not otherwise be a problem, became one. ----- *A 30 minute check for slow air leaks is sometimes called a Kamen Test. Dean is not the only visiting dignitary who waxes eloquent, but he does have the highest visibility. |
#7
Yes they should have checked their pneumatics for leaks to prevent that from occurring, but if it wouldn't be a problem in a normal match then they shouldn't be penalized. Now if the fall out of dimensions between the time they place their robot on the field, during the normal team introductions and flag waving, before the MC says 1, 2, 3, RUSH, er I mean go, then yes they should be DQ'ed. |
#8
We had a similar problem some years ago. We use a piece of tape to hold the mechanism in place. The tape would pull away once the mechanism actuated.
