Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 17-02-2016, 23:12
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
amstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to behold
COMMS HELP NEEDED
Hi!
Today I tried to connect to a new RoboRIO on our robot. I had a ton of problems connecting through the OM5P-AN. Basically, I had already used the OM5P-AN with a different roboRIO, and when it wouldn't connect I figured that I needed to reset and re-configure the OM5P-AN. After some problems, I finally accomplished that. But I still couldn't connect. Then I tried an old D-Link, still not luck. Physical ethernet tethers didn't work, so I tried re-imaging it. It wouldn't show up on scans.
Then, I just put in an old roboRIO and I still couldn't connect. But, I can ping it just fine. I re-imaged that old one and it worked, but then when I try to get into the web dash with ethernet I got this error:
"Could not retrieve configuration data from target. This could mean that the target's web server is temporarily unavailable or that your installation is corrupted. Please refresh your browser. If this problem persists, please contact National Instruments support."
I don't know what to do at this point. My firewalls are down, and I am running Windows 10.
Recap: I can connect via USB to web dash. I can ping the roboRIO. I can't connect via ethernet to the Webdash. I can connect via USB to driver station. I can't connect via ethernet to DS.
Unread 17-02-2016, 23:17
Noviv's Avatar
Noviv Noviv is offline
FRC #1477 (Texas Torque)
Noviv is an unknown quantity at this point
Re: COMMS HELP NEEDED
Firstly, have you updated driver station? When you open driver station, the name of the window should be 16.0.1 or something like that.
Secondly, have you tried connecting the RoboRIO to your driver station with ethernet, skipping over the router? If you can't connect this way, then there is probably something wrong with the ethernet port, or even the RoboRIO itself.
Worst comes to worst, just reinstall all FRC software and reimage the RIO.
Good luck!
Unread 17-02-2016, 23:21
AKA: Anja Sheppard
Version 16.0.1 for the DS.
I am connected directly to the RoboRIO.
I guess I will try reinstalling all FRC software. Thanks for the help!
Unread 17-02-2016, 23:31
Noviv's Avatar
No problem!
If reinstalling & re imaging doesn't work, I would also check that you are either using roboRIO-####-frc.local or 10.##.##.2 when you connect through a web browser.
If you still can't connect, try running
arp -a
while connected to the robot and posting the results. A list of addresses should appear, and one needs to be the robot's address, otherwise something else is wrong.
Unread 18-02-2016, 08:00
If USB works and an ethernet cable doesn't, please check the control panel settings to see if the laptop is setup for DHCP. The USB is an ethernet protocol bridged over USB.
Greg McKaskle
Unread 18-02-2016, 15:48
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Try turning off your Windows firewall.
Brian K
Team 1225 Robotics Mentor
Unread 18-02-2016, 20:55
AKA: Anja Sheppard
For some reason, the ethernet connection is wokring now, but I still can't connect to the OM5P-AN to configure it.
Unread 18-02-2016, 22:52
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
We had a very similar problem.
We did this -- http://wpilib.screenstepslive.com/s/...o-for-home-use
Then we reinstalled and updated our driver station.
Now it works.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
