Go to Post wow Paul and Rich in a photograph, i thought that if that much nerd got together that a black hole would form - Mike Schroeder [more]
Unread 17-02-2016, 18:14
cantdecide cantdecide is offline
FRC #5773 (YAFL Mechatronics)
Rookie Year: 2016
cantdecide is an unknown quantity at this point
Using the PCM to control a LED
We're using a custom LED assembly for illuminating the retro-reflective tape and it needs ~300 milliamps at 12V, meaning we can't use DIO, and because it heats up so quickly, we can't directly hook it up to the VRM(having the LED be on during the whole match would probably destroy the LEDs). I would have traditionally done this with a boring transistor, but it was 4 am(when the best ideas are formed) in the morning, and we had no transistors. That's when it suddenly came to us: we already had a device that had regulated 12V outputs which can be controlled via code: the PCM! We hooked up the LED to one of the solenoid outputs on the PCM, and it worked just fine. We checked the manual to see whether doing that was legal or not, and according to Table 4-4 under R53, CUSTOM CIRCUITS(I assume that our LED assembly is considered a CUSTOM CIRCUIT) can be controlled using the PCM. However, I still have the urge to ask: is this legal? It just feels so odd and honestly, it's something I wouldn't have allowed if I wrote the rules.
Kinda off-topic: third party fans for ESCs aren't allowed but wiring lights to solenoid slots is. Rules are weird.
Unread 17-02-2016, 18:16
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: Using the PCM to control a LED
We used this last year in week 2 and it wasn't an issue.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 17-02-2016, 18:29
Rookie Year: 2016
Alright, it's comforting to see that another team has done this.
Unread 17-02-2016, 19:28
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
You could also use a Spike relay to control your LEDs.
Unread 17-02-2016, 23:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The last row of table 4-4 (R53) explicitly allows 1 custom circuit to be controlled by each PCM channel.
Do keep a good eye on the per-channel and total current drawn by the PCM in any given state.
Another alternative is to use a 12V opto-isolated relay module. These can be controlled from DIO ports or relay ports, and are much smaller and less expensive than a spike for custom circuit loads of up to 10A.
Unread 18-02-2016, 02:06
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Can I ask a simple question? How BRIGHT is this LED assembly that would destroy the LEDs over the period of a match? The retro-reflective tape doesn't require all that much illumination and I'm now worried about a proverbial "light cannon" (as I've heard robot mounted flashlights called recently) shining into the opposing drive teams eyes. Remember that you aren't just on level ground but tilted if you are crossing the defenses at all.
Just curious is all...
Nate
Unread 18-02-2016, 02:38
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
A 300ma 12v led could be easily cooled by using a 3w led heatsink like the kinds you can find on ebay or local electronics stores. If the led is on a star, using thermal paste and screws to attach it to the chassis would heatsink it enough alone (the stars are usually isolated).
Unread 18-02-2016, 13:15
Rookie Year: 2016
It's pretty much as bright as the ring light in FIRST Choice, but with much higher light per surface area(the ring light has 15 LEDs and outputs 304 lumen, meaning ~20 lumen per LED, whereas our assembly has 3 LEDs in total and outputs ~275 lumen(LED guy quote), so about ~90 lumen per LED). I'm trying to keep the light disabled as much as possible because of the nuisance factor. At the moment, it's only turned on when the robot is aiming towards the goal, which shouldn't take longer than 3 seconds(and the aim method has a 10 second timeout).
Unread 18-02-2016, 13:36
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
We use both an LED ring light from Superbright LEDS for the camera targeting as well as a high-power LED for manual targeting. Both lights are driven off the same Spike relay module which we've used in past years.
Note: our lights are pointed upward and we only turn them on when we need to use them. Otherwise they stay off so as not to unduly distract the opposing castle defenders.
Unread 22-03-2016, 08:00
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Any info on your setup with the Spike relay would be appreciated... i am trying ot get this going with a 12v to 3.3V converter but the 2 LEDs flashlight i used so far don't seem to hold up.... I have a nice bright light at forst, remove power then re-apply and then i can barely see it....
