Go to Post I know what "finished" means, and I know what "robot" means, but what is this "finished robot" of which you speak? - Rick TYler [more]
Unread 18-02-2016, 00:19
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
Please Answer My Question !!!!
If I wanted to make my shooter shoot in autonomous how would I do that ?
Also can anyone show me a example of a autonomous program ?
Also how do I set up different autonomous programs to choose from in SmartDashBoard ?
Please Answer the following questions programming geniuses.
I'm Running a Iterative Class
Unread 18-02-2016, 00:21
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Please Answer My Question !!!!
Are you running command based in Java?
If you are, then your autonomous program is litterally a command group with a sequence of commands.
you add your commands like this
addSequential(new myCommand1);
addSequential(new myCommand2);
if you want to run 2 commands at the same time:
addParallel(myCommand1);
addSequential(myCommand2);
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 18-02-2016, 00:25
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
In AutonomousPeriodic, turn on your shooter and shoot.
Now, if you want to score, and avoid fouls (like having to be in contact with the courtyard carpet before launching a boulder), that is much more difficult.
Starting from the Spy Box would be a much easier problem. When your team places the robot, line it up with the goal.
Have some method to set a variable: dip switches on the robot (connected to analog or digital input), Digital switches on the Dashboard, or use a field on the smart dashboard.
In AutonomousInit, read the switches.
In AutonomousPeriod, do whatever you have to do, based upon the switch setting.
BTW: Can you drive your robot yet? That is a more fundamental problem. If you can't drive, you can't do much in Autonomous, or Teleop.
Unread 18-02-2016, 00:26
FRC #5713
Thank you for replying but I am running Iterative
Unread 18-02-2016, 00:28
FRC #5713
Thank you
Unread 18-02-2016, 00:32
FRC #5713
Rich
Yes we can drive
Unread 18-02-2016, 00:44
Re: Rich
Yes we can drive
Autonomous is just like Teleop. The only difference is: Instead of getting commands from the Controller, you pre-define the sequence of commands.
So, drive straight for a period of time. Shoot the Boulder.
Unread 18-02-2016, 13:49
mreynolds's Avatar
mreynolds mreynolds is offline
Team Captain | Head of Controls
AKA: Matthew Reynolds
FRC #4946 (The Alpha Dogs)
mreynolds is an unknown quantity at this point
If you create an example program in eclipse, it should have an example of how to use the smart dashboard to select your auto script. You should find a SendableChooser object in the robot.Java, which is the radio-button selector thing in the smart dashboard
Unread 18-02-2016, 13:50
mreynolds's Avatar
If you can't find it, feel free to PM me I can walk you through it. I'd just send you resources now, but I'm only on my phone
