Go to Post This isn't a science fair, sometimes it's okay to give away the answer, especially if they learned something on the way there. - Karthik [more]
Unread 18-02-2016, 00:50
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
G39 - Autonomus
How many robots will get G39 fouls during Autonomous?
G39 ROBOTS are prohibited from launching BOULDERS unless they are in contact with the opponent’s TOWER or carpet in the opponent’s COURTYARD, and not in contact with any other carpet. Violation: TECH FOUL per BOULDER
A robot gets stuck on the Defense, and then blindly shoots the boulder.
I'll have to tell the programmers to check their position, and do not shoot if not in the right place.
Unread 18-02-2016, 01:02
Jaci's Avatar
Jaci Jaci is online now
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Re: G39 - Autonomus
This is harder than you think. Unless your vision system can accurately tell distance (and therefore derive your position on the field), there isn't much your programmers can do. Most defences like the Rough Terrain or Ramparts will render encoders basically useless until you're on flat ground again.
That being said, I think a lot of teams will get stuck on defences, or read their position inaccurately, during autonomous. However, some teams may have a way to mitigate this
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 18-02-2016, 01:04
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Re: G39 - Autonomus
I do not foresee this being an issue with my team, but I do think this will be fairly common and something to keep track of when scouting.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 18-02-2016, 01:11
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
Re: G39 - Autonomus
Everyone's roboRIO has an accelerometer built into it.
If a team can't use that to tell the difference between being flat on the floor or sitting on a defense before firing... I will be very sad.
I might even go around at events making sure every team that plans on shooting, that our team would play with in quals at least, can utilize that feature to ensure no fouls.
John Fogarty
Unread 18-02-2016, 01:29
Jaci's Avatar
Rookie Year: 2015
Re: G39 - Autonomus
Accelerometer =/= Gyro. Although 2 dimensions worth of data can be derived from the accelerometer, for most teams, this is not worth the effort. The RoboRIO's accelerometer has a lot of drift associated with it. This was also discussed Here
Even if a team decides to implement this, they still have to reorient to face the goal and shoot, for which they need to determine their distance and angle to the goal. If their vision is capable of this, it negates the need for a gyro in the first place.
Jacinta R
OpenRIO : Owner
Unread 18-02-2016, 06:55
Re: G39 - Autonomus
Does the Camera can see the goal in the right place? if not, don't shoot.
If you are lined up with the goal, then I'd risk taking the shot.
We have a NavX, so hopefully we can get some useful data from that.
Unread 18-02-2016, 07:48
Jaci's Avatar
Rookie Year: 2015
Re: G39 - Autonomus
You can be on a defence and still have acquired a valid vision tracking target. (i.e. middle defence). We're trying to avoid that issue as much as possible
Jacinta R
OpenRIO : Owner
Unread 18-02-2016, 09:20
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: G39 - Autonomus
You don't need a gyro to figure out if you're on flat ground. You don't need to integrate at all. When you're stopped, check the accelerometer. The relative sizes of the X, Y, and Z axes will tell you the RoboRIO's orientation. Unless the mounting has broken loose, you can then figure out the robot's orientation.
Shooting based on an integrated inertial navigation position is likely to be a waste of time. If you aren't using vision code or otherwise aligning the robot to field elements, you're unlikely to hit a high goal. At least practice this to find your shot percentage so you can figure out whether the extra five points when you make it is worth the time to track the boulder down when you miss.
Don't just acquire a target; let it tell you where you are. The farther away you are, the smaller it shall appear. Don't shoot if the target is too small.
Unread 18-02-2016, 09:25
Chris is me's Avatar
AKA: Pinecone
Re: G39 - Autonomus
I continue to think we are vastly overestimating the number of teams that will successfully shoot high goals in autonomous. This is one of many, many issues teams will have in doing so.
So this won't be a big deal, if only because less than half a dozen teams per event will be successful in auton any way and other teams will stop trying to shoot.
Unread 18-02-2016, 10:28
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
Re: G39 - Autonomus
Drift only matters when you're double integrating for position. Using the accelerometer to determine which way is down will be very accurate.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 18-02-2016, 10:33
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: G39 - Autonomus
It's not quite this simple to tell if you are stuck on a defense though. Teams can still be trapped on defenses when their robots are parallel to the floor. This will be very common on the moat, and could still happen with many other defenses.
Unread 18-02-2016, 10:37
foote stepped in
AKA: E. Foote
FRC #0868
Re: G39 - Autonomus
In that case, one could monitor the current going to the drive motors... if the drive wheels are spinning free they're not in contact with the carpet.
Unread 18-02-2016, 10:39
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: G39 - Autonomus
We're mounting color sensors to the underbelly of our robot. We'll be watching for green, then not green, then green again.
Hi!
Unread 18-02-2016, 10:47
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
Re: G39 - Autonomus
I don't necessarily see the accelerometer as a viable option for getting reliable data in autonomous unless you plan on only crossing defenses with level surfaces (unlike the moat or rough terrain). Otherwise, you will find that the inaccuracy of the accelerometer will hinder your tracking of positions on the field.
2013-2014: Electrical, Mechanical
2014-2017: Team Captain
Unread 18-02-2016, 10:48
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: G39 - Autonomus
Unless you just plan to use the accelerometer to sense when your robot has settled back down. Don't need to know you are flat, just need to know you are not moving all over the place.
