Go to Post There was no real separation between who did what. "we" did it all and it was fun. - Team2339 [more]
Unread 18-02-2016, 05:14
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: States for SMC 3 position valve
Just having two soleniods on the valve does not make it 3 position. If it is, then both soleniods off sets center position. You never want to energise both solenoids at the same time. Do you have the full part number handy?
Two position dual solenoid valves stay in the last state energised. IE extended or retracted which is what you are describing?
