Go to Post I don't miss the manufactured magic of Disney because Championships creates magic in itself; wherever the event may be held. - Erin Rapacki [more]
Unread 17-02-2016, 19:10
tig567899's Avatar
tig567899 tig567899 is offline
Team 6070 Programming Captain
AKA: Tiger Kong
FRC #6070 (Gryphon Machine)
Rookie Year: 2016
tig567899 is an unknown quantity at this point
Robot Bag legality
Are we allowed to cut part of the robot bag and use it on our robot? I can't find it in the rules.
Unread 17-02-2016, 19:25
Re: Robot Bag legality
I would use a standard trash bag, of sufficient toughness. It's not illegal to use the robot bag, but it's a very, very bad idea.
One of the very first things that happens at your event is that the inspectors will go over your bag. If there is a hole in it, particularly one that looks deliberate or that happens to be big enough to work on the robot, you will be having a nice conversation with your inspector. If it's big enough, the Lead Robot Inspector will also be involved.
Unread 17-02-2016, 19:55
tig567899's Avatar
AKA: Tiger Kong
Rookie Year: 2016
Thanks!
Unread 17-02-2016, 20:02
Out of curiosity, how tough of a bag do you need? Do you need it to be clear?
If not, go with a standard tarp. http://www.canadiantire.ca/en/pdp/ce...l#.VsUYr_krK00
Unread 17-02-2016, 20:33
tig567899's Avatar
AKA: Tiger Kong
Rookie Year: 2016
Tarp would work, but we need it to be see-through.
Unread 17-02-2016, 20:35
NinjaMunkeeNao's Avatar
NinjaMunkeeNao NinjaMunkeeNao is offline
i'll literally do whatever :D
AKA: Naomi Christina Alexander
FRC #2395 (The Ninja Munkees)
Rookie Year: 2016
NinjaMunkeeNao is an unknown quantity at this point
I found clear trash bags at WalMart. Here's a link to them online (though I've seen them in stores, too): http://www.walmart.com/c/ep/clear-trash-bags
Hope this helps!
Unread 17-02-2016, 20:44
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
You can buy clear plastic sheeting at any hardware or paint store. People use it to keep stuff dry on construction sites, as dropcloths for painting, and for a bunch of other things. It comes in various lengths and thicknesses. Just check with your local Lowes or Home Depot. They, or anywhere that sells lumber, might also have clear plastic sheeting just lying around. I know when I worked at a lumberyard, when we got shipments of fancy lumber like mahogany, it was totally wrapped in thick translucent plastic sheeting, and to us it was trash. If you just ask, someone will definitely have some that you can probably just take for free.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 17-02-2016, 20:45
Come to think of it...
What exactly are you working on? If it doesn't need to be flexible, you may want to pick up some Lexan and use that instead.
Unread 17-02-2016, 20:46
Rookie Year: 2016
Why didn't I think of Lexan? Good idea!
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Hope this helps!
I think places like U-Haul sells bags for mattresses and such, usually clear and heavy weight.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 17-02-2016, 20:47
Rookie Year: 2016
Also a good option.
Unread 17-02-2016, 23:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Clear plastic sheeting is also available as painting drop cloth, and sometimes as a vegetation/root screen in the gardening section of your local home center, though this is more likely to be opaque or just slightly translucent. (The stuff was as precious as gasoline around here after Hurricane Katrina.)
Unread 17-02-2016, 23:38
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
some fabric shops ( maybe even some walmarts) sell table cloth protrectors, some flexible clear film, comes in a few thicknesses, it is usually sold from a roll so you only need to buy enough for what you need.
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
2016-Present FRC 1360 Orbit Community Robotics Mentor, Design and Manufacturing
Unread 18-02-2016, 06:58
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Better yet, go to a mattress store and ask if they have a bag they are throwing away. You might get it for free.
Unread 18-02-2016, 07:38
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
A simple solution would be to cut the portion you need from the top of the bag (whatever will be "north" of the tag once your robot is bagged). This way if that bag material is really the material you are looking for, you could use it without raising eyebrows about your bagging procedure and robot access after bag day.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
