Go to Post sign up to be an organ donor, and encourage your friends to be organ donors. - dtengineering [more]
Unread 18-02-2016, 07:38
viggy96 viggy96 is offline
FRC #3331
viggy96 is infamous around these partsviggy96 is infamous around these parts
Originally Posted by FrankJ View Post
Without knowing the what the actual valve is, I cannot give any advice on programming it.
On the physical side. If you cannot fully vent the pneumatics from the high pressure vent, your pneumatic system isn't FRC legal. Closed center three posittion valves tend to prevent that
I gave the model number of the valve before, but here it is again: SY5320-6D-N7T. It is manufactured by SMC.
Unread 18-02-2016, 16:31
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: States for SMC 3 position valve
Silly my for try to read this on my phone. Anyway that does look like the part number for a 3 position valve. The valve should block the A&B ports & lock the cylinder when both solenoids (the physical ones) are de-energized. If not the valve isn't that part number or something else is wrong that programming will not fix. Another possibility is the cylinder is acting faster the valve. If so you will need flow restrictors in the cylinder ports.
You probably want to use two solenoid objects and set them both to off rather than the double solenoid object. The net result should be both solenoids off.
